severe bucking
Old Feb 23, 2004 | 06:11 PM
87MarkVIILSC's Avatar
87MarkVIILSC
Angry severe bucking
i have a 87 lincoln mark VII and i'm havin severe bucking problems throughout the rpm range. fuel mileage is low and it had the check engine light on but i disconnected the egr and it went out except for when you first start it and go to pull out, it will come on only 1 time. i already replaced the wires, cap, rotor. where should i look next
Old Feb 23, 2004 | 07:37 PM
WALJON's Avatar
WALJON
DOES that 87 have a co2 sensor?
Old Feb 23, 2004 | 08:29 PM
EPNCSU2006's Avatar
EPNCSU2006
Pull the codes before you go replacing anything. http://fordfuelinjection.com and then on the left side "Getting Codes."
Old Feb 25, 2004 | 04:25 AM
Burple's Avatar
Burple
Check your fuel pressure regulator, My truck had all the same problems and thats what it was for me!
Old Feb 25, 2004 | 07:32 PM
87MarkVIILSC
yeah it has an 02 sensor
Old Feb 25, 2004 | 08:39 PM
bigwheelin's Avatar
bigwheelin
just my .02
I recently had a similar problem with an 89 mark. It had a galloping idle, poor fuel mileage, major loss of power, and some bucking. Ended up being a rusted fuel pump line (right on the pump where the steel line attaches to the plastic line) resulting a drop in fuel pressure.
Old Feb 26, 2004 | 07:09 PM
WALJON's Avatar
WALJON
Have you ever changed it? does the engine have lots a miles?
Old Feb 27, 2004 | 04:37 PM
87MarkVIILSC
never changed the O2. it has 139,000
Old Feb 29, 2004 | 07:33 AM
WALJON's Avatar
WALJON
I would say its that ,I had that problem on an 89 bucking and stuff the check engine light would only come on some times went and changed almost every sensor in the motor reading the codes , and it was the CO sensor after that many miles you should change it anyway IF that doesnt work check your plenum gasget ITS cheep to do run the car let it warm up spray wd40 around the bottom of plenum see if it changes the idle of engine good luck!
Old Feb 29, 2004 | 07:15 PM
87MarkVIILSC
ok i'll check that plenum gasket and change the o2 sensor and the fuel filter while im fixing the stupid air suspension and the exhaust. thanks for the advice
Old Mar 4, 2004 | 07:26 AM
cliffordthetruck's Avatar
cliffordthetruck
I recently had the same problem it turned out to be the TPS (throttle position sensor) It was reading the trottle as full open all the time. Therefore the mix was rich.
Old Mar 4, 2004 | 07:38 PM
87MarkVIILSC
I had a bad experience with the car today. i left work and only got to the end of the parking lot and the car shut off. i restarted right away and heard the serp belt screamin away so i threw it in reverse and got as far as i could back into the lot till it died and was spewing white smoke out from under the hood. i got out and started moving parts to see what went wrong, alternator was ok, ps & water pump too. got to the smog pump and it was seized like no other. so after i get around to puttin some tranny fluid in the pump n try to loosen her up and get a new belt on it, i hope this is the cure for the trouble all long
Old Mar 6, 2004 | 07:11 AM
WALJON's Avatar
WALJON
I know it sucks that the pump packed it in,but maybe its a good thing, now (if its the problem)you wont be looking for a needle in a hay stack good luck!
Sunvalleyson
Oct 16, 2013 11:48 AM
zakk
Dec 18, 2011 10:18 PM
licardox
Jan 13, 2011 09:00 PM
RuffRanger
1978 - 1996 Big Bronco
Feb 23, 2007 08:49 AM
