83' 6.9 tachometer wiring HELP
Old Feb 22, 2004 | 10:47 PM
tinsmith's Avatar
tinsmith
Lightbulb 83' 6.9 tachometer wiring HELP
Hi,
Well I have a problem, I have a 83' F250 6.9. I changed out the cluster to one with a Tach in it, I was told that the wiring was already there and it would work. Well it doesn't!
So what do I need to do to make the Tach work??
Old Feb 23, 2004 | 06:44 AM
bultaco370's Avatar
bultaco370
i think you need a tach sensor. it goes in the cover right behind engine oil fill cap. should have a wire with plug not hooked to anything. i put the sensor in mine but havent got a tach cluster from wrecking yard yet. if you dont find it i can email a picture of mine tonight.
Old Feb 23, 2004 | 09:36 AM
fellro86's Avatar
fellro86
are there any aftermarket units available? I haven't seen them, but I would like to put a tach in mine, as it is a 4 speed, and I believe to be 4:10 rears, and I want this baby to last.
Old Feb 23, 2004 | 06:58 PM
tinsmith's Avatar
tinsmith
Hi,
The Email would be great!
danerio@comcast.net
Old Feb 23, 2004 | 07:04 PM
tinsmith's Avatar
tinsmith
Tach's
Hi,
Yes there are, you can try this place.
http://www.issproinc.com/Home/webstore/SUBMENU/t.html
They are in Portland Or. and have everything you could want.
Old Feb 25, 2004 | 05:27 PM
redneckmechnic's Avatar
redneckmechnic
If it wouldnt be to much trouble could ya email me a pic to i to bought a tac and cant get it to work. were did ya get the sensor and how much did it run ya. ya can email me at redneckmechanic9 at hotmail . com i spaced my email out so that hopefully no automated computers can figure it out but any one with two brain cells can.
Old Feb 25, 2004 | 06:22 PM
bultaco370's Avatar
bultaco370
i emailed you some pictures
Old Feb 25, 2004 | 06:24 PM
bultaco370's Avatar
bultaco370
the wire to hook to sensor is in the harness going to alternator. it should be there like the plug i took picture of.
Old Feb 26, 2004 | 01:06 PM
redneckmechnic
Hey thanks for the email. Did ya get the sensor thro ford or someone else. also do ya just thread that sensor in there or did ya have to put a magnet or somthen else on the pump drive gear. Thanks alot I really apprciate it.
Old Feb 26, 2004 | 04:29 PM
bultaco370's Avatar
bultaco370
I GOT IT FROM A FORD MECHANIC AT HIS HOME. HE HAD IT ON AN OLD 7.3 and just screwed it in. he said get a tach and it will work.
Old Feb 26, 2004 | 06:37 PM
redneckmechnic
okay thanks have to check with ford and or napa see what i can do. thanks for the info tho.
Old Feb 26, 2004 | 10:39 PM
tinsmith's Avatar
tinsmith
Well it seems I have a Cluster with a Tach in it that I can't use, anyone need it?
I paid $48. for it. I'm going to put my other cluster back in, with the Banks tach.
Old Feb 27, 2004 | 02:51 AM
ncshooter's Avatar
ncshooter
tinsmith, e-mail sent
ncshooter
Kenneykole
13
May 7, 2012 04:37 AM
scottscott
Apr 22, 2010 04:08 PM
IDIDieselJohn
May 12, 2009 04:02 PM
IDfordguy
Sep 26, 2005 01:00 PM
Distinctive Dave
Dec 14, 2002 02:32 PM
