transmission code?axle code 1991 diesel
Old Feb 27, 2004 | 05:18 AM
smashing4455's Avatar
smashing4455
Question transmission code?axle code 1991 diesel
Does anyone know the what a "45" axle code and a "E" trans code is on a 1991 F350 diesel? i am also converting to 4 wheel drive is it correct that the gear ratio in the front and the back have to be the same?
Old Feb 27, 2004 | 05:44 AM
pnose's Avatar
pnose
Code 45=non posi 4.10.The tranny E40D,And yes the front needs to be the same as the rear or one set of tires will turn at a different speed than the other.
Old Feb 27, 2004 | 06:16 AM
smashing4455
thanks for the info
