vacumn hose
Old Feb 22, 2004 | 06:33 PM
dbwood55's Avatar
dbwood55
vacumn hose
I just had my 82 ford f-150, 302, converted from 4 to a 2 barrel, i noticed a hose coming out of the back of the carb that is not connected to anything. where should it connect to?
Old Feb 22, 2004 | 06:44 PM
BigGene's Avatar
BigGene
What is the diameter of the hose? It could be a number of things but the size will narrow it down. BigGene
Old Feb 23, 2004 | 05:00 PM
dbwood55's Avatar
dbwood55
the hose is small, 1/8"ID
Old Feb 23, 2004 | 06:23 PM
Chugalug's Avatar
Chugalug
Mine has got one that size comeing out of the EGR valve. and I don't know where to hook it back up.
maby I can hook mine to the carb.
Old Feb 23, 2004 | 08:08 PM
bremen242's Avatar
bremen242
that hose might be the hose that powers the flapper valve on the air cleaner for the heated air intake
Old Feb 25, 2004 | 05:15 PM
dbwood55's Avatar
dbwood55
THATS WHAT I WAS THINKING, THERE ARE TWO INLETS ON THE BOTTOM IF THE AIR FILTER BODY ALSO ON THE SNOUT OF THE AIR FILTER BODY THERE IS A SMALL CANISTER THE SIZE OF A SNUFF CAN WITH AN INLET FOR A VACUMN LINE. SO MANY CHOISES ONLY ONE HOSE!!!
Old Feb 25, 2004 | 07:19 PM
Chugalug's Avatar
Chugalug
I found where mine hooked up at today and now it don't spark knock and ping as much under light acceleration.
Old Feb 26, 2004 | 02:16 AM
redneckdieselmechanic's Avatar
hooked up to the vacuum advance on the distributor right?
