New truck
Old Feb 24, 2004 | 11:06 PM
steve0101's Avatar
steve0101
New truck
I just got my first truck; it is a 1985 f-150 4X4 paid 300 for it. It needs allot of work rust on everything but it runs good. What I would like to know is where I can get new leaf springs the ones on the truck are broken. Thanks for reading my post
Steve
Old Feb 25, 2004 | 10:47 AM
iskybantilus's Avatar
iskybantilus
not sure where u are from, but if u can find a local spring supplier, or parts store should be able to get them, if not, jc whitney, and any of the off road supply shops have springs ranging from stock to whatever lift you want. if u plan on towing or hauling, i would get the heavier duty rating springs of the choices, if stock replacement.
Old Feb 25, 2004 | 11:05 AM
mramc1's Avatar
mramc1
Try Espo Springs at Espo.com. I had good luck with their springs I bought for another vehicle.
Josh
Old Feb 25, 2004 | 07:25 PM
864x2mudder's Avatar
864x2mudder
Try summit, jcwhitney, jegs, and lmc truck find the lowest price. Get some paint and bondo and ur good 2 go!
Old Feb 25, 2004 | 09:02 PM
steve0101's Avatar
steve0101
thanks for all the help
I have one more thing right know the srpings are for 1/2 ton can I make it into a 1 ton and if I can how would I go about ding that?
Old Feb 26, 2004 | 06:46 AM
iskybantilus
if it has 3 inch wide springs, then u can get the heaviest load rating springs for a bronco, which is like 2850 lb springs, straight out of stock replacement, that should be heavy duty enough for that truck.
