Rear Axle / Differential Code breakdown, please
Old Feb 21, 2004 | 07:27 PM
garykansascity's Avatar
garykansascity
I just purchased a used rearend, the tags reads "S 836B 3 08 88 2E08"
What does this code breakdown to be, please
Gary Becker (The new guy to 4x4)
Old Feb 21, 2004 | 07:31 PM
pops_91710's Avatar
pops_91710
That's it? I always thought the tag also had the gear ratio on it.
Old Feb 21, 2004 | 07:34 PM
mikelehmann's Avatar
mikelehmann
keep looking there might be another tag on your rear
Old Feb 21, 2004 | 07:40 PM
pops_91710's Avatar
pops_91710
S = Light & Heavy Truck Special Order Parts
308=3.08:1 axle ratio? (seems awfull tall) What is it for?
Old Feb 21, 2004 | 07:49 PM
78fordman's Avatar
78fordman
it's a 8.8 isn't it?
Old Feb 21, 2004 | 08:02 PM
82F100SWB's Avatar
82F100SWB
Yup, 3.08 geared 8.8"... F150 axle I'd assume...
Old Feb 21, 2004 | 08:12 PM
garykansascity
The new guy
o.k. 3.08 ratio, would the tag give info if it was a open or posi differential?
I purchased it cheap, and was going to keep the axles, differential and gear out of it as spare parts for my 1984 Ford : F-150 Lariat 4x4
The 3.08 is way too tall, will probably sell that on EBay, but was hoping that it had a posi chunck in it and keep the axles as spares.
Was pulled from a 1992 F150
Gary Becker
Old Feb 21, 2004 | 08:54 PM
pops_91710's Avatar
pops_91710
That explains why it's 3.08 being in an F-150.
OEM#=E7TZ4209A / Teeth= 40 ring-13 pinion/
Ratio: 3.08 , Diameter of ring 8.8"
I don't believe the 3.08 was ever offered in anything but limited slip. So, you got a winner.
If you can get back to the truck you took it off of, look on the door plate. If the axle code is H8, it's without a doubt LS. But again, the 3.08 came only in LS to my knowledge.
Old Feb 22, 2004 | 01:31 AM
Boss_358's Avatar
Boss_358
Its open. There is no L in the ratio. If it was limited slip the ratio would be 3L08, or something like it.
Old Feb 22, 2004 | 02:44 PM
garykansascity
Well, seems everyone agrees that it's a 3:08 ratio (bad for me) but 50/50 on it being a Limited Slip. Will pull the differential tonight and let you all know the end result. But hoping that it's a Limited as Opens are worthless to me.
Gary Becker
Old Feb 22, 2004 | 03:11 PM
kspilkinton's Avatar
kspilkinton
Definitely not a factory LS unit from your tag. I'll tell you that right now. As far as 3.08's only being LS's... never have heard of a 3.08 LS unit.
Sorry, but it looks like it's worthless to you even before you pull it.
-Kerry
Old Feb 22, 2004 | 03:50 PM
garykansascity
Great Debate is over, but silly question
o.k. Gentlemen, I opened up the Rearend and it's a 3:08 Ratio - Open Diff.
But, how can Ford list it as either 2wd or 4wd with an Open Carrier????
To be a True 2wd or 4wd doesn't it have to have either a Limited Slip or Locker???
Gary Becker
Old Feb 22, 2004 | 03:58 PM
pops_91710's Avatar
pops_91710
KERRY SAID "never have heard of a 3.08 LS unit."
https://www.ford-trucks.com/articles/axlechart.php
Here it is guys, right out of the pages of our very own FTE.
Axle code H8 is a 3.08 LS made by Ford. Just thought you would like to know.
Old Feb 22, 2004 | 06:07 PM
garykansascity
On that Carrier, I don't openly see any Clutch Plates nor Spring between the spider gears. So I'm assuming it's a Open Carrier, if that's correct?
Gary Becker
Old Feb 22, 2004 | 06:23 PM
kspilkinton
OK Pops, you got me there. Doesn't seem like you'd want a hihg gear like that with an LS or locker. Still doesn't help Gary, in either case. It's an open unit. All manufacturers call their trucks 2 or 4WD even with open rears and fronts. Can you call it false advertising? Don't know, it's been going on forever.
-Kerry
