Air Horn
:-X23
:P
:-staun
:-X12
:-X11
:7
disclaimer-that guarantee in no way obligates me to pay for any fines that you may incur in heeding my advice.
lol... train whistle, jump aboard!
anyhow.... i think i need two systems now... one 140db system and one of those that plays songs.... so depending on what part of the city i am in i can score!
Your not gonna get the ones that play "La cucaracha" are you?
yes it plays that as well as others.... dude, there is a large hispanic population close to me... so i don't want to leave all those hot little honeys from south of the border out.... i am an equal oppourtunity horn blower! lol.
>Bigdeezil, I'm awaitin' fer that address.
Here ya go fellas. These are nicer than mine. I could'nt find chrome ones when I was there. Big $$$ for these. Maybe they will have less-expensive ones if you call.
[link:www.iowa80.com/iowa80/servlet/productdisplay?prodid=06758|TOOT-TOOT]
I wanted to mount the horns on the roof for maximum sound, but I would have a clearance problem with my slide-in camper. So I settled for behind the front license plate. It’s not quite as loud as the roof install would be, but there’s still plenty of noise. I just made a bracket to bolt them to the bumper that positions the horns behind the license plate. The compressor is mounted to a aluminum plate that’s bolted to the frame and radiator support below the battery. The air tank is on the left side of the engine compartment on a custom bracket. The nice thing about the air tank is that it has a shrader valve on it to hook up the included coiled air hose. I use the air supply to air up airbags/tires or once to blow crap out of a propane stove with a air nozzle I carry.
I wanted the horns to run off the stock horn button, so I just tapped into the horn wire in the engine compartment. I did install two switches in the cab. One of the switches disables the air horn if I want just the factory horns (good idea in MA apparantly). Otherwise, all horns blow together (although you can’t hear the factory ones over the Hadleys). The other switch in the cab allows me to turn the compressor off if I don’t want to listen to it run.
added on edit:
You can buy these horns at www.jcwhitney.com or at camping world.
Harald
2000 F350 4x4 CC DRW V10 4.30ls Lariat LWB.
Firestone Ride-rite airbags, Rancho RS9000 shocks and Torklift Superhitch.
1998 Alpenlite Pendelton 11'10" camper held on by Torklift tie downs.
