door lock key pad 2002 explorer
Old Feb 19, 2004 | 07:58 PM
snowshoe's Avatar
snowshoe
I just bought an '02 eddie bauer explorer with a key pad on the door. The vehicle did not have original manual. In order to program the key pad I must enter the code which I don't have. The manual says the code is taped to the "computer module". Without tearing the car apart , where is this module?
Old Feb 19, 2004 | 10:11 PM
ltfox's Avatar
ltfox
On my 2000, its located inside over the driver side wheel well. Their is plastic panal that can be removed. Then looking inside the door to the front of the vehical you can see my modual. The number was printed on the side of this modual. You may need a mirror to look up their and read it. Yours may be the same?? Iduno, hope this works.
Old Feb 19, 2004 | 10:12 PM
ltfox's Avatar
ltfox
Sorry I forgot to mention that its over the rear wheel well on the driverside, inside the vehical.
Old Feb 20, 2004 | 05:41 PM
1956MarkII's Avatar
1956MarkII
See "Keyless Entry Codes" thread, second one from top in this forum.
Old Feb 26, 2004 | 06:58 PM
snowshoe's Avatar
snowshoe
the 2002 model explorer is a new body style. The computer module is not located on the wheel well as in the older body style. The only way to retreive the code is at the dealer with a computer hook up. The manual is incorrect according to a ford technician. Thanx for trying to help.
pcollins
Aug 3, 2011 12:31 PM
cnelso48
Sep 3, 2009 03:25 PM
kystangbanger
Apr 14, 2009 06:18 AM
RAGaz
Apr 25, 2007 10:00 AM
gksportster
Feb 25, 2007 01:02 PM
