Mobile 1 Worth the money?
Saying that Mobil One prroducts are worth the money is a far too general of a statement. It would be like saying that Ford makes the safest cars. Would you want to be rearended in a Pinto or a Crown Victoria? If so, I'll watch from a distance. Some of the M1 products are great, some are not so great. The 5w-30 is great, the 0w-20 is not so great as it typically is beat in UOA's by blends everyday. Delvac 1 is great and is most likely the best PAO basestock synthetic on the market today including any boutique oil you would like to mention. Is it worth more? Depends on what you are buying.
Flash, from some of your posts I've noticed that you are impressed with Delvac 1, except that it is expensive. I've looked for it at my local Wally World with no success, do you have any suggestions at to where I might find it? Also, what would be the typical price that I might pay once I'm able to track it down? Thanks.
Everything is relative and sometimes religious.
I have used Mobil 1 since 1980 and never had a problem. Previously I used dino(Valvoline) and also never had a problem, so I can't say with firm personal proof that Mobil 1 is worth the money, but it has never failed me even under extremes.
From marketing, magazines and websites I would say if you drive under temperature extremes, heavy loads, high performance or long drain intervals, a synthtetic may be worthwhile for you.
To me the psychological safety blanket of knowing I have more performance in oil than I might need is worth the extra cost. Plus I change at 5K to 7.5K intervals rather than the "recommended" 3K for dino.
I will say that many of the newer generation dinos look to be quite excellent and very synthetic like in performance. I have also read some articles that lead me to believe that many of the current syntehtics, including Mobil1 and Valvoline syn are really just dino hydro processed to almost syn performance with a little real syn added to handle the low temp issues.
I recently looked up the Mobil 1 and Valvoline syn webpages and none of them out right state that their syn is the "real" pure PAO or Ester syn of years gone by. They taked about "unconventional high performance base oils", in my interpretation this means they are using the cheaper hydro processed dinos with a little PAO added for low temps and calling them synthetic and charging a syn price.
There is a lot of argument among purists whether hydo dino really is syn. I am waffling here myself. If the hydro dino acts like syn and performs like syn, is it really syn and does it matter? I think where I waffle is that the hydro syns should cost less than "real" syn but some of the oils called "real" syn charge "real" syn prices even if they are really mostly hydro.
Buying oil today is good and bad. Do you really get the real thing? Does it really matter? In anycase almost any name brand is excellent stuff whether it is "real" syn, hydro or plain old dino.
As for me, at least for now I will probably keep using Mobil 1 in my car(just because), Valvoline syn in my 460(always loved Valvoline and now that they have syn, well) and Havoline syn(I think this is Chevron syn) in the wife's car since it is cheap. I use syn now mostly for religious reasons.
I might break down and switch to the Chevron or Rotella hydro dino syns since they appear to be excellent oils and low cost.
Just my opinion,
Jim Henderson
Just my opinion,
Jim Henderson
gregb, if you can't find Delvac 1 around in your area, look for the nearest CAT dealer. The CAT Synthetic is the same oil with a tracer element for analysis differential. If CAT likes it, it has to be good. Most of the CAT dealers will sell it in bulk so ask if you call them and be prepared to take some 1 or 5 gallon containers with you. It's really the best way to buy it.
