Heated Seat
Old Feb 19, 2004 | 09:33 AM
u2deere's Avatar
u2deere
Heated Seat
Hi, this is my first post. I order a 2004 Lariat with caption chairs. Living in Minnesota I included the heated seat option. My question is: the seats only stay on for 10 minutes before turning off. Is there a way to change this?
Old Feb 19, 2004 | 10:16 AM
dneinstadt's Avatar
dneinstadt
Not that I know of, but you will notice it RIGHT away when they do shut off.
I'm in MN too, where you at?
Dan
Old Feb 19, 2004 | 01:39 PM
Dr No's Avatar
Dr No
Just hit the button again for another 10 min.
Mike
Old Feb 19, 2004 | 02:56 PM
u2deere's Avatar
u2deere
I know that pressing the button would be an option. My question is related to starting the truck on cold mornings and letting it warm up and be assured that the seat was warm when you entered. We test drove some trucks on a morning at the dealer in Apple Valley where the outside temp was -10 below. Needless to say in 10 minutes the seat has not completely warmed up. Just wondering if anyone had an idea to extended the run time.
Old Feb 19, 2004 | 08:08 PM
rferoni's Avatar
rferoni
I am thinking of getting a lariat and was thinking of this very problem. I know what I will be doing....the heated seat buttons need to be wired to the ignition with a toggle switch. The reason? If you have a toggle switch you can turn the switch "on" when you exit the vehicle for the night. This way when you get up to go to work you don't have to go outside to hit the buttons. Having to go outside would negate the money spent on the remote start
Now how one would go about this I'm not sure, but I like the idea!!
Ron
Old Feb 20, 2004 | 08:51 AM
dneinstadt's Avatar
dneinstadt
Rferoni, The heated seats automatically shut off after 10 minutes. Your toggle will work but it will shut off after 10 minutes unless you bypass the factory timer.
Dan
Old Feb 20, 2004 | 09:58 AM
1956MarkII's Avatar
1956MarkII
We've tried to "pre-warm" seats on the lot before someone takes a test-drive. Start the truck, turn on the seat heater, let it run for 10 minutes. You know what? It doesn't work. I think what happens is the heat just escapes into the air; it seems you actually need a body sitting on the seat to retain the heat.
Old Feb 20, 2004 | 10:03 AM
2004lariat's Avatar
2004lariat
My wife has a 2003 Explorer and her heated seats turn of after about 10 min. as well but come back on a short while later when they get cold again. When she turns off the SUV and starts it agian they go back on automatically. Not sure if the Lariat is any different or not. I hope not, I have one coming in April
F-150 Lariat Black 2 Tone Black interior - Loaded - Time for the waiting game.
Old Feb 20, 2004 | 10:16 AM
2004supacrewlariat's Avatar
2004supacrewlariat
I wonder if there is a reason for the 10min shut off. I would consider not changing anything. Maybe these things overheat or burn out with periods of extended use.
