General Automotive Discussion
Spark plug bigger gap
Old Feb 18, 2004 | 09:29 PM
carpe_diem's Avatar
carpe_diem
I just realized that I may have gapped the spark plugs for my F250 larger than the specs. I tuned it up this summer and since then, it has run well. Problem was, the specs said something like 0.044" but when I used a round device with different gaps, I pushed it all the way in, resulting in 0.055", about 0.010" bigger.
Is that really bad? Should I take them out and regap them? I want to check one first and see its gap.
Reason I found out, I was installing the plugs on another vehicle and realized I was gapping them wrong when I realized that when I pushed the round disk all the way in, it increased the gap by 0.010".
The engine is 460 (EFI) and the plugs are Autolite.
Old Feb 18, 2004 | 09:45 PM
Mil1ion's Avatar
Mil1ion
Are you talking about the metal gauge that has number around the perimeter ?
Look for the .044 spot and thats where to gap the plug against.
The thickness changes on those things.
Old Feb 18, 2004 | 09:52 PM
carpe_diem's Avatar
carpe_diem
Yes, I am talking about the round metal gauge which has numbers around the perimeter all the way across. It typically sells at auto parts places for 99 cents.
I think I used it incorrectly. Instead of sticking it between the two metal surfaces of the spark plug, about 2 mm or so, I found 0.044 spot and pushed it in maybe 5-7mm. The thickness seems to vary from the edge towards the center even if you remain with the same 0.044 spot.
Sorry for being so tedious, but you know, the devil is in the details.
I am going to pull one plug and see if it is indeed 0.044 like it should be. I should do it anyway to examine it.
Really, the plugs were easy on that engine, except for one.
Old Feb 18, 2004 | 10:13 PM
Mil1ion's Avatar
Mil1ion
Considering the center electrode erode's, I set mine on the less side of .044" allowing it to get more space through use.
I alwys slide the ground electrode in at the narrow edge and measure by slowly moving it around.
Old Feb 18, 2004 | 10:28 PM
fordeverpower's Avatar
fordeverpower
no it won't hurt a thing! Generally more gap is more spark and more power but you won't notice it one way or another. leave it until next time
Old Feb 19, 2004 | 02:09 AM
Matts72's Avatar
Matts72
Yeah, like fordeverpower said, it can increase power but only if you run a higher output coil and low resistance wires. If you have a CD buzz box, then you can run the bigger gap as well, because some of them send out 12 sparks for every normal one, so you are gonna get complete burn.
Old Feb 19, 2004 | 03:55 AM
CowboyBilly9Mile's Avatar
CowboyBilly9Mile
It's harder to fire a cold plug than a hot one so you may experience harder starting and possibly rough running/driveability issues, especially when cold. IMHO, investigate and set to factory specs on a stock engine. After all, if a wider gap resulted in a benefit, I'm sure the manufacturer would have loved to deliver that benefit to the customers when it was new.
Old Feb 19, 2004 | 05:22 AM
Bob Ayers's Avatar
Bob Ayers
I agree with Cowboy, the plugs should be set to spec. The increase gap means a higher voltage is required, which will but
more stress on plug wires, etc. ....If a wider gap was better, then
an engine would run better on worn out plugs!!!!
Old Feb 19, 2004 | 05:53 AM
tomw's Avatar
tomw
Bigger is not always better... Take 'em out, and set the gap correctly. You may get a little better burn with a larger gap, with attendant stress to the components, but you run the risk of a misfire when you push the limit. The guys have it right. Why suggest .044-.046 when bigger would be better? Because it has enough 'spark' to get the mix fired AND it fires reliably. It will most likely run smoother with the correct gap.
My 2 cents. Change please...
tom
Old Feb 19, 2004 | 07:43 AM
Big Orn's Avatar
Big Orn
Carp,
If you slid the plugs in at the .044” setting, then pushed it all the way from the lip to the inner shoulder of the gauge it should still be .044”.
Unless I’m not understanding the gauge settings right. It should only change thickness the further up/down the scale you go, not in or out. Of course you could have a bad gauge and it would vary.
Old Feb 19, 2004 | 09:04 AM
carpe_diem's Avatar
carpe_diem
That's what I thought but I just tuned up my Topaz, doing just that and found out that gap was really 0.055, not 0.045. Had to remove the plugs and regap them.
That makes sense. I am definitely going to pull one of them out and investigate. Luckily, they are easy to swap, all but maybe the rear driver's side plug. (Took me 40 mins to find the right extensions, but once I did, it was easy).
Maybe I should also replace my spark plug gapping tool, I think it is wrong.
Old Feb 19, 2004 | 09:08 AM
Bob Ayers's Avatar
Bob Ayers
Yes, the "wire" type of gapping tool is the best. If your gapping
platinum plugs, be careful not to damage the platinum "beads".
Old Feb 19, 2004 | 02:02 PM
Matts72's Avatar
Matts72
Do not ever try to gap a platinum plug. They are designed to be perfect from the factory.
Old Feb 19, 2004 | 03:33 PM
superrangerman2002's Avatar
superrangerman2002
Some are, some aren't.
Old Feb 19, 2004 | 03:37 PM
Bob Ayers's Avatar
Bob Ayers
I've found the same thing. You HAVE to use the "wire" type of
gapping tool on platinum plugs, you CANNOT use the circular
gapping tool!!!
