Sponsored by: Real Truck
need help
Old Feb 18, 2004 | 02:52 PM
MooseC's Avatar
MooseC
Question need help
Hello all this is my first time on one of these forums so I hope i'm doing this right. I have a question for anyone who can help me. I have 1996 F-350 with the 460 in it and I am trying to get better proformance out of it as well as fuel milage. I don't want to pump up the motor or anything like that I am looking for bolt on componets for this beast. I talked to Banks about a system for this truck but I am looking for someone who has tried this out a gas powered motor already. If someone has any other ideas for me I would be greatful for the info.
MooseC
Old Feb 18, 2004 | 03:23 PM
99f350sd's Avatar
99f350sd
Welcome to the site! I'm sure you will get what you deserve...I mean what you came for...Couldn't help myself..sorry
more power???= no fuel mileage. Law of diminishing returns..
I'm pretty negative on bolt on crap.
Dick
Old Feb 18, 2004 | 03:57 PM
MooseC's Avatar
MooseC
Hey Dick I thank you for the reply. I'll tell you Banks told me with there system I would get 30% more feul mileage and another 98 ft lbs of torque and another 50-80 horse. In your opnion is it bull?
Old Feb 18, 2004 | 04:02 PM
99f350sd's Avatar
99f350sd
Welllllllllllllllllllll.. I think I have heard some things about those kits and it wasn't negative but HP claims are alittle hard to believe..Go on their website and look around..I'm sure someone from hea will chime in tonight....Oh and better fuel mileage I don't know about 30% maybe 10%....
Old Feb 18, 2004 | 04:09 PM
99f350sd's Avatar
99f350sd
If you look at their charts you gain about 10 hp at 2000 rpm thats where you would normally tow something...I wouldn't do the kit for that I would do a super charger..
Old Feb 18, 2004 | 04:39 PM
MooseC's Avatar
MooseC
Hey, thanks alot for the info. I have crappy take off when towing my toyhauler and the top end just doesn't work well for me but killer midrange it seem. I was just approched today buy a guy to get a super charger. Will it help all through the power ranges? If so it may be the way to go. I'm also thinking about doing 3" exhaust it should help. I have a single flowmaster on it now maybe I sould go with two. What are your thoughts on that?
Old Feb 18, 2004 | 04:46 PM
99f350sd's Avatar
99f350sd
Opening up the exhaust will hurt you lower end...Stock should run the best for the design. Whats the weight of your trailer?
Super charger 3-4 thousand big ones but you'll go go go..
That motor should be fine I don't understand maybe your gearing is too high? What is it?
Old Feb 18, 2004 | 04:55 PM
99f350sd's Avatar
99f350sd
http://www.motorhaven.com/customer/home.php?cat=169
Check this out
Old Feb 18, 2004 | 05:02 PM
MooseC's Avatar
MooseC
Well the trailer loaded is close to 10,000lbs and my gear ratio is 4:10's. I know the gearing should be fine. It is a 5 speed stick shift. Being a stick should be even better. I can't figure it out.
Old Feb 18, 2004 | 05:06 PM
99f350sd's Avatar
99f350sd
Maybe its just not running correct ...That trailer is quite heavy though. How about a new 6.0 for 40k
