high peformance igntion coil
Old Feb 17, 2004 | 10:05 PM
fordfan2018's Avatar
fordfan2018
im thinking of buying a 60,000 volt coil from jcwhitney. my question is with my point-style igntion system will the new coil cause any damage? will it increase peformance at all?
Old Feb 17, 2004 | 10:08 PM
fordeverpower's Avatar
fordeverpower
just curious what coil puts out 60,000 volts cause the most i have seen is the super coil at 50,000 volts? Make sure the plug wires are not touching!
Old Feb 17, 2004 | 10:19 PM
fordfan2018
like i said its in the jcwhitney catalog. page 83, im not dreaming this up now... to my question.
Old Feb 17, 2004 | 10:25 PM
fordeverpower
to your question, I don't believe it will cause any damage or really increase performance. If you get the coil and have good plugs and wires it might help. But i look at it this way. If you had a big carb it should do more than have a smaller one. The increased spark would burn up the excess gas but if your motor runs lean or good I don't see how it would help a lot. It might allow you to richen the mixture and will provide more power increases then but the mpg would suffer. But it does when you talk power anyway!
Old Feb 17, 2004 | 10:27 PM
proeliator's Avatar
proeliator
No. A hotter igntion/coil will not damage anything. It can reduce the lifespan of plugs, points, etc. I hadn't seen a 60,000 volt coil before either and I certainly would think twice about buying ignition components out of jc whitney. There are more bad "performance" coils out there than good ones.
Old Feb 17, 2004 | 10:31 PM
fordeverpower
i just got done looking at it 60,000 volts for 26 bucks and no name of manufactur. I don't know but it wouldn't hurt to try I guess. I like to go to summit or jegs before jc whitney myself.
Old Feb 18, 2004 | 01:22 AM
Ratsmoker's Avatar
Ratsmoker
I've done the cheap coil thing (Accel). My MSD keeps me happy. If you need more spark than that then get an MSD 6A. No coil alone can match it or any of its equivalents.
Old Feb 18, 2004 | 12:01 PM
Putt's Avatar
Putt
The points are the limiting factor in getting any increases out of a hi-output coil, because the points control coil saturation time via the dwell. That's why ANY electronic ignition will put out more voltage than a points system , and more consistently.
Old Feb 18, 2004 | 12:35 PM
BB's Avatar
BB
Usually a high-performance coil needs a different (lower) value resistor wire (ballast resistor) than the stock one, does it make any reference to that?
Old Feb 18, 2004 | 12:47 PM
rusty70f100's Avatar
rusty70f100
That's why it's so important to have your dwell accurately set when you use points.
My brother was telling me a story of his old mustang (I'm thinking it was a '72) that used points. He would run it up around 7000 rpm, and it had power up there! Anyway, he tried cheap points, and there was fire shooting out the exhaust at that engine speed. So the quality of them does matter.
I like to use Blue Streak points on my truck, with an Accell Super Stock coil. It puts out 42,000 volts, which is more than stock, but wont fry anything. It seems to work good.
Old Feb 18, 2004 | 12:53 PM
fordfan2018
it just says that the ballast resistor is included.about the points whats the best quailty points i can get from autozone,adavance auto, etc?
Old Feb 18, 2004 | 01:22 PM
rusty70f100
Go to carquest, and ask for their premium points. They'll give you Blue Streak points, which are the best IMO. That's what my brother ran in his mustang FWIW.
If you dont have a dwell tach, get one, as it's essential when you set points. Set the dwell to 28-30 degrees.
Good luck!
Old Feb 18, 2004 | 04:22 PM
Putt's Avatar
Putt
I agree the point quality is important and Blue Streak is as good as it gets. The prob is after running for a while the dwell changes due to point and rubbing block wear--it doesn't change with electronic and it is more than what you can get with points.
Old Feb 18, 2004 | 04:24 PM
fordaholic-67F100's Avatar
fordaholic-67F100
Lose the points FAST! get a good reman electronic pick up DIST and at least a dura spark module. I would go with the MSD 6A if you can swing the money right now. also remember that even with a stock electronic IGN ststem you are limited by the amount of DWELL or coil build up time. any after market CD system is the tops. Capacitive Discharge uses a bank of capacitors to store the juice not the coil. if you go with a CD system remember to use quality wire and use 10 guage to feed the box from the BATT. this is where the capacitors get thier juice, so dont skimp on the wire guage here. last but not least GOOD GROUND connection.
Old Feb 18, 2004 | 07:06 PM
78fordman's Avatar
78fordman
I have a MSD blaster 2 coil, and i do not see much performance difference, but easier cold starts, once the engine is running for about 5 seconds, it will sit there and idle just fine with the choke off. It is leaned up about as far as a can get it without burning out my exhaust valves.
