engine swap
Old Feb 16, 2004 | 06:54 AM
Larry M.'s Avatar
Larry M.
engine swap
HI, I am thinking about swapping out my 5.0 liter for an inline six...I have a 92 F150 e40d tranny , 2 wheel drive,,,,any help out there would be appreciated..what do I have to switch,,,,exhaust,,computer,,wiring,,, I am looking for a 300 six,,,the same year as my truck,,,will this help.. ??
Thanks,
Larry M.
Old Feb 16, 2004 | 03:01 PM
AlfredB1979's Avatar
AlfredB1979
Change all the above. Find a 4.9L donor truck. Basically you are changing the engine, mounts, radiator, engine harness.
The hard part for my friend who did the swap to a 302(?) was changing out the I6 towers so he could get the v8 mounts in.
car-part.com might help, but a lot of salvage yards ought to have donors sitting.
I like the I6 too, but the 351 would be easier in your case.
Old Feb 16, 2004 | 03:58 PM
Larry M.'s Avatar
Larry M.
I can get a 1995 inline six,,, complete with alternater, pumps and brackets for $600.00....this is from a crashed 1995 truck, with only 60,000 miles on it......is it worth the trouble ?? need something soon
Old Feb 16, 2004 | 04:32 PM
swann79's Avatar
swann79
$600 ain't bad... depends on what you would prefer as an end result. That I-6 has better low-end torque, but the 302 holds better horsepower at high rpms.
If you like the idea of the strong bottom end, then it might be worth your trouble, esp. for the price.
But if you don't want to lose the high end of the V-8 then I would shop around for another 302 (easier swap) or upgrade to the 351. The 351 would outperform both engines in all categories
Old Feb 16, 2004 | 05:23 PM
Larry M.'s Avatar
Larry M.
Thanks,,,but I am looking for the tech. advice as what is needed...I ain't looking for a conversation on what is better...I know you mean well,,,,but really looking for how its done and what is needed
Old Feb 16, 2004 | 06:05 PM
Matts72's Avatar
Matts72
I'd leave the 302 Radiator, I think they are actually the same.
Yes you need the computer and motor mounts/towers. The wiring into the cab and too the buzz boxes is the same.
$600 for a complete running 300 I6 isn't bad. There are several header manufacturers for this motor, which really wakes it up.
With a good friend, you can have this swap done in about 10 hours.
good luck, and welcome to FTE.
Old Feb 16, 2004 | 09:19 PM
Larry M.'s Avatar
Larry M.
Thats what I needed to know ...thanks Mattsbox...this is from a 1995..and I have a 1992....both are running with the E4OD....what are the buzz boxes ??/...so its the motor complete,,,the computer,,,,exhaust...and towers,,,I reallyappreciate it,,,thanks,
Larry
Old Feb 16, 2004 | 09:21 PM
Larry M.'s Avatar
Larry M.
P.S. ...Mattsbox....you say the wiring into the cab is the same for both engines ,,from 1992 to 95,,,am I reading that right...I hope so,,,thanks again
Old Feb 16, 2004 | 10:50 PM
Matts72's Avatar
Matts72
Yep, thats gonna be the same. Buzz boxes are the random control modules. Things like the throttle cable, brake booster, that kind of stuff, they are interchangeable.
Old Feb 17, 2004 | 08:05 AM
Tepot's Avatar
Tepot
question? Why the hell would you want to swap from a V8 302 to a I6 300?
I got the 300 4.9L in my truck and I'm tired of it. I'm gonna swap the engine for a V8 302 5.0L.
More power in a 302 and sound's alot better too.
Old Feb 17, 2004 | 08:07 AM
Tepot's Avatar
Tepot
Oh, by the way. My truck is a 1994. if your truck in the 92-96 range. I could probably buy your wire harness, computer, and flywheel if you want to sell it.
I've already got a 302 but need the flywheel, computer and wire harness
let me know
Old Feb 17, 2004 | 04:20 PM
Matts72's Avatar
Matts72
Please place wanted/for sale ads in the classifieds.
You can edit posts up to 60 minutes after you post them to add information or to change things, rather than posting another message.
Old Dec 26, 2020 | 02:21 AM
Chris Flores's Avatar
Chris Flores
Need to make some changes
So I have a 89 F250 4x4 460 Automatic I want a carberated Small block 351 bo I need a new tranny also? What will fit this truck?
WVVan
Sep 25, 2018 04:10 PM
WVVan
32
Apr 1, 2017 04:56 PM
kopy kat
6.7L Power Stroke Diesel
Oct 26, 2015 08:54 PM
WVVan
May 27, 2015 03:53 AM
Larry1981
1978 - 1996 Big Bronco
Jun 11, 2007 07:20 PM
