'96 Explorer XLT engine and tranny
Old Feb 15, 2004 | 03:34 PM
Outlawery's Avatar
Outlawery
Exclamation '96 Explorer XLT engine and tranny
I bought 1996 Explorer XLT with 4x4 and auto tranny for real low price, although it has bad main bearing (possibly other areas) and check light engine code comes up with one code and that is P0756 which means shift solenoid "b" indicates inadequate performance or a "stuck off" condition....
I need opinions and advices from all of you experts on my choices...
it has 4.0L engine and im not sure if its ohv or not (how do i tell??) and im thinking maybe i go with replacing the motor with same engine... or do i try to upgrade to 4.0 (not ohv) or perhaps a 5.0?? are the tranny and 4x4 same for all three motors??
OR, do i go ahead and order engine rebuild kit and rebuild from bottom, replacing all bearings, maybe replace rings on pistons???
as for tranny, i think i will go with rebuild unless not advised. I would say I am mechanically expert and have done many engine works and rebuilding and overhaul-- but money is my biggest concern right now and i need it running ASAP since I got real tight schedules. Any inputs would be greatly appreicated!!
Old Feb 16, 2004 | 10:13 AM
Outlawery's Avatar
Outlawery
guess what,.. i found engine at real good price also so i think im gonna go with swapping 4.0 ohv and rebuilding the tranny... how do i tell if i have 5r55e or 4r55e tranny?? i believe 5r55e is made for '97 and newer??
Old Feb 16, 2004 | 10:19 AM
87MarkVIILSC's Avatar
87MarkVIILSC
1996's had 4.0 SOHC which is better than the OHV pushrod engine. it should say on the plastic intake cover like my 02 explorer that its a 4.0L SOHC. stick with the SOHC cause you might have to change stuff on the engine if you go back to the OHV pushrod. 4r55e is a 4 speed, 5r55e is a 5 speed.
87MarkVIILSC
Old Feb 16, 2004 | 08:59 PM
Outlawery's Avatar
Outlawery
got the engine today... its ohv motor... looks excat the same what i have in explorer. Now, for tranny... for somebody with good mechanical background would you encourage me rebuilding the tranny myself? i have rebuild motors many times but never a tranny...
Old Feb 16, 2004 | 10:37 PM
96explorereddieb's Avatar
96explorereddieb
SOHC didn't come out until the '97 model year. It was the V8 that was introduced in '96.
jimkari
Oct 21, 2019 01:56 PM
WillFargo
May 23, 2010 09:09 AM
dybeepvw
17
Jan 29, 2010 07:36 PM
rickvo
May 7, 2006 09:52 PM
joners
19
Apr 11, 2006 06:22 AM
