93 explorer temperature driving me crazy
Old Feb 15, 2004 | 12:09 PM
rob_engineer's Avatar
rob_engineer
Question 93 explorer temperature driving me crazy
I have a 93 explorer with 156K miles. For the past two months I have been trying to solve a temperature problem. The gauge fluctuates quite a bit and the temperature level is generally lower than it should be. I also have low heat in the cabin. I've changed the thermostat two times and the temperature sensor once with no change to the behavior. I did notice today that one of the heater core hoses runs cold while the other is hot. Could all of my problems be caused by a blocked heater core? Please give me your suggestions.
Thanks,
Rob
Old Feb 15, 2004 | 01:41 PM
rob_engineer
Well, today I removed the heater core. There was some stuff in it that would have seriously hampered the flow of coolant. After putting it in, I certainly fixed the heat in the cabin problem. Now I just have to see if the fluctuating temperature on the gauge goes away.
Old Feb 15, 2004 | 05:58 PM
mrshorty's Avatar
mrshorty
I've seen fluctuating temperatures caused by a clogged heater core. It could also be a sticky thermostat. If it hasn't gone away, that would be my next check.
Old Feb 16, 2004 | 09:29 AM
jclj2003's Avatar
jclj2003
yea my navajo has the same problem i will try to clean it out today and see if it helps i will keep u updated
Old Feb 16, 2004 | 01:55 PM
77redf250's Avatar
77redf250
did you change the sensor to the gage i believe you motor has 2 temp sensors the computer uses the other one
Old Feb 16, 2004 | 04:19 PM
rob_engineer
I think the problem is fixed. If so, all along it must have been a clogged heater core. As an engineer, I just don't see how a clogged heater would cause the engine temperature to fluctuate as much as it did. But, that has to be it because changing the thermostat and gauge sensor didn't do it. I drove the truck to work today. I had heat and the engine temperature was quite stable!
Thanks,
Rob
Old Feb 16, 2004 | 05:41 PM
77redf250's Avatar
77redf250
when the thermostat is closed the coolant circulates within the block and heatercore the thermostat has a bit of a transition of a few degrees between completely opening and closing, once it's completely open the cold coolant in the radiator is imediately sucked up into the hot engine block and the cycle continues. the heater core is just a small heat exchanger(radiator) that keeps the temperature more stable by removing heat at a fairly constant rate a little higher with closed thermostat and lower when it's open due to the pressure drop when opening and closing the thermostat. sorry about all this i'm an engineer too. glad to hear you gotter fixed
Old Feb 16, 2004 | 06:27 PM
rob_engineer
Hey, thanks. Your explanation makes sense. Now if I can just get the ping to go away.... (I've read up on that subject hear and plan to try to decarbonize the intake. Started pinging about two years ago. I switched to super and the pinging went away. It recently started to ping on occasion, even with super gas.)
Old Feb 16, 2004 | 09:25 PM
77redf250's Avatar
77redf250
looks like you solved it!! don't use the cheap stuff!! i'd say your on th right track i've heard of people adding a little kerosine or diesel in the tank to loosen carbon buildup in the combustion chamber. you could try running plugs 1 or 2 heat ranges lower. and you may have a bad knock sensor(more likely than not). good luck makin her run like new
Old Feb 16, 2004 | 11:08 PM
mrshorty's Avatar
mrshorty
...you may have a bad knock sensor(more likely than not)...
I'm not sure your '93 Explorer even has a knock sensor. I know my '92 doesn't.
If decarboning the cylinders doesn't get the ping to go away, try cleaning the MAF, tightening the lower intake manifold bolts, and check for other vacuum leaks. Those are the other common causes of "ping" on the 4.0 OHV.
