Driveshaft Help?
Old Feb 15, 2004 | 11:21 AM
JCPSME's Avatar
JCPSME
Driveshaft Help?
I need a drive shaft for my Panel. It's a 1954 F 100 6 cyl 3 spd. What other trucks, years or models, would have the same one? What is the length? I've read on here that the pickups and panels have the same frames so I'm assuming the drive shafts could be interchangable. Any input would be appreciated or if you might have one laying around...... Thanks
Old Feb 15, 2004 | 01:02 PM
Fomoko1's Avatar
Fomoko1
Check out your wheel base , that should give a starting point. Find a similar year, w/b and compare for length. If trucks have the same w/b as your panel then measure to make sure there is room for suspension travel for the yoke to move in and out of the transmisson out put shaft. Don`t know how much is needed but suspect 1 to 1.5 inches.
Old Feb 15, 2004 | 08:17 PM
joners's Avatar
joners
I have one from my 54 with Flathead with 3spd.
Email me if you'd like it, I've been trying to find a buyer for it for a long time.
Old Feb 19, 2004 | 08:54 PM
JCPSME's Avatar
JCPSME
Sounds like a plan fomoko1 and Thanks joners.
Old Feb 20, 2004 | 09:58 AM
joners's Avatar
joners
That reminds me, I beleve I still have the yoke as well
Old Feb 21, 2004 | 09:01 AM
joners's Avatar
joners
Yes it has the yoke.
Boehnlein79
Feb 18, 2013 08:03 PM
zehcnasca
23
Nov 11, 2011 07:13 PM
autochefc
Aug 1, 2011 11:02 PM
surfersoldier
Dec 15, 2010 06:02 PM
KJKozak2
Apr 18, 2002 12:13 AM
