drive shaft trouble
Old Aug 1, 2011 | 09:28 PM
autochefc's Avatar
autochefc
drive shaft trouble
ok I have a 1974 f100 4x4 and the center collar bearing is out on the rear drive shaft but every where I look it seams that they list the drive shafts with collar bearing as 2x2 should I change it to a diffrent drive line or just look for the same one? the total distance fron t case to rear axels is 75 1/2 " could I get one single axel or would that couse the off roading to be harder?
Old Aug 1, 2011 | 09:47 PM
fordguy76's Avatar
fordguy76
The later 70s 4x4s are a single drive shaft to the rear. You could convert it I suppose. Check your local junk yard and make sure the yokes match up with what you have.
Old Aug 1, 2011 | 11:02 PM
400 .040over's Avatar
400 .040over
i looks an i find them for 4x,most auto part stores carry them any were from 25.00 up to 150.00
neelsnoles
2009 - 2014 F150
Jan 17, 2019 07:49 AM
jbas
Oct 10, 2016 07:46 PM
83capril
13
Jul 11, 2011 07:51 AM
Forest
Jul 17, 2006 10:21 AM
