Anyone ever build a Fozzy locker?
Old Feb 15, 2004 | 12:56 AM
ClatonK's Avatar
ClatonK
How did it work? Any trouble? Tips?
Thanks,
Clayton
Old Feb 15, 2004 | 02:28 PM
BroncoRoadKill's Avatar
BroncoRoadKill
Fozzy locker? Do you mean a lincoln locker. cause thats when you weld the spider gears in your carrier, Kinda like a spool.
Old Feb 16, 2004 | 09:10 AM
Andysutt's Avatar
Andysutt
For the money, I'd go with a minispool
They sell for 35 bucks down here all day long.
Just gotta tell them what spline axles you have.
I wouldn't recommend the lincoln locker
Old Sep 6, 2006 | 08:59 PM
montster's Avatar
montster
actually fozzy is a member of one of the BC(canada) and he started welding 2 opposing gear teeth full on each spider so it only allows a 1/4 turn before locking, if you search "fozzy locker" then take the BC4x4 link you should find it
Old Sep 6, 2006 | 09:39 PM
bob s jr's Avatar
bob s jr
spoon or limited slip would be better good solid traction but not good in cornering that was a old hot rodder trick and 4 wheelers did it to before the days of spools limited slips and such mini spool through jegs or summit is 35 dollers and less work
Old Sep 7, 2006 | 11:06 PM
ClatonK's Avatar
ClatonK
I did it last fall in the front diff of my 80 F250. I did not do a Fozzy locker, I welded it solid. It works great and I have amazing traction. You just have to know when to lock both hubs or just one. And to drive carefully. In addition, there is a proper process to weld it up so the cast case does not become weak. And it was nearly free$.
ClatonK
Jun 20, 2005 11:57 PM
ClatonK
Jan 26, 2005 06:26 AM
ClatonK
Offroad & 4x4
Oct 2, 2004 05:19 AM
ClatonK
Jan 2, 2004 12:52 PM
41Clay
Jul 8, 2003 07:35 AM
