Dashboard Repair
Old Feb 17, 2004 | 04:50 AM
willowbilly3's Avatar
willowbilly3
Originally posted by Fritolay
wow looks good and for $30 better the the $90 for a cap
Who sells the caps for 90? I saw them in JCW for 119
Old Feb 17, 2004 | 02:37 PM
whiteyford's Avatar
whiteyford
That job looks amazing! You have inspired me to attempt this with my 1970 f-100. I have a friend who is very handy with the sewing machine, so that helps. Was the vinyl you used backed with felt, or did you purchase them seperately? Also, what kind of calk did you use to seal up the cracks, because I have quite a few of them.
Also, did you wrap the material all the way underneith the dash, or just to the visable edges and glue it? Thanks for the help!
Old Feb 17, 2004 | 03:07 PM
The Fife's Avatar
The Fife
My dash has cracks so wide I found a nickel lost under there!
Old Feb 17, 2004 | 10:00 PM
jambroson's Avatar
jambroson
Whiteyford,
I purchased the vinyl seperately from the felt. Try to find a thin stretchy felt. I wound up using two layers. One layer down the middle of the dash and one layer over the whole dash. Don't get to hung up on the Chaulking. You can use cheap chaulk and it does not have to be totaly flush with the dash. I was amayzed at how much the felt covered up. Where the speaker vent was I used a piece of plastic and duct tape to cover the hole then I glued the felt over that. I wrapped the vinyl under the dash about 1-3 inches depending. Remember, don't glue the vinyl to the felt.
Let me know if you have any more questions.
Josh
Don Vito
18
Apr 4, 2017 09:21 AM
albany23
Feb 7, 2017 01:46 PM
Ford_Convertee
Sep 8, 2012 08:57 PM
monster693
Mar 4, 2010 07:39 AM
Imdok
Appearance & Dress-Up
Nov 19, 2007 03:36 PM
