Stereo Won't Work
Old Feb 14, 2004 | 02:41 PM
WarriorHeart's Avatar
WarriorHeart
Unhappy Stereo Won't Work
My 94 F150 radio/cd player has the word BAD in the face plate and will not turn on or shut off. The word bad comes on once the vehicle starts up. Is there a solution or fix, or should I get a new stereo.
Old Feb 14, 2004 | 03:28 PM
acerockola77's Avatar
acerockola77
Is it the stock headunit?
Old Feb 14, 2004 | 04:34 PM
WarriorHeart
Yes, it's stock. It has the ford emblem across the face plate. Will I need a new harness if I put a pioneer stereo in it.
Old Feb 14, 2004 | 05:14 PM
larry derouin's Avatar
larry derouin
When you get a pioneer unit, get one of the wiring harness adapters (about $15.00) for you year vehicle. Solder the wires from the adapter to the matching wires on the head unit.
Match up the mounting adapter and plug it in.
Just for S&G. Disconnect the battery for about 15 minutes. Then re-connect and turn on the radio. Sometimes the CD unit will go bad and jam up the whole works. Disconnecting the radio might just let it reset.
Larry
Old Feb 14, 2004 | 07:46 PM
WarriorHeart
Thumbs up Thanks For The Help
Larry
Mikey_23_ny1
May 23, 2014 05:00 PM
1999 ford big girl
1997 - 2003 F150
Aug 22, 2013 11:18 PM
Fat Ford Boy
1997 - 2003 F150
Mar 12, 2012 06:04 PM
945SPD
Jun 11, 2007 08:15 PM
Jarlaxle
49
Sep 14, 2003 12:06 PM
