Oilguard location
Old Feb 14, 2004 | 08:10 AM
stiffysteele's Avatar
stiffysteele
Oilguard location
I Just got my oilguard by pass. Where should i put the bracket pfor this thing. Any recommendations would be most helpful. I was thinking of up by the full flow, but the dive shaft for the four wheel wheel drive might get in the way. Please help me.
Old Feb 14, 2004 | 08:30 AM
bilder12's Avatar
bilder12
I dont know about the oil guard system, but I have my fs2500 on the outside of the frame under the driver door, connected by high pressure lines to the filter area. I would also imagine there would be instructions included with the filter assembly for the oil guard. There is my nickle . Good luck.
Old Feb 19, 2004 | 09:39 PM
DarrellM5's Avatar
DarrellM5
I'm going to install mine where the photos show on their website when it gets here (shipped today). A friend of mine installed his in the left wheel well. I'm not sure if that was a good spot though.
Old Feb 20, 2004 | 08:23 AM
HeatStroked's Avatar
HeatStroked
I installed mine horizontally on the inside of the frame rail on the drivers side. Mine is a 4 x 2 but you should have the same holes in the frame. Within 18-24" of the high pressure outlets.
I fabricated an "L" type bracket to mount the Oil Guard bracket too.
See the following, 3 pix;
http://community.webshots.com/photo/...15330739tMiVoe
Old Feb 20, 2004 | 01:03 PM
Zilard's Avatar
Zilard
When you mount them horizontally is it messy to change the filter cartridge? Mine should be here today or monday.
CH
Old Feb 20, 2004 | 05:13 PM
HeatStroked
No, the mount that I fabricated moves the filter 2 inches away from the frame rail, so it wont leak onto that.
Sure, you'll have to break it open and thread the cover a bit and let the oil it run out a bit before totally removingjust like your normal filter.
I just couldn't find a place to mount the Oil Guard vertically and have room for the hoses and not pose a potential ground clearance problem.
bkvanbek
Mar 14, 2010 08:55 AM
Oil Guard Tech
Apr 22, 2006 06:00 AM
moosekingranch
Aug 18, 2005 05:40 PM
mrc59
May 26, 2005 06:29 PM
Oil Guard Tech
Sep 5, 2004 11:57 PM
