67 2-wd 5-speed?
Old Feb 13, 2004 | 07:02 PM
GT-Racer's Avatar
GT-Racer
Question 67 2-wd anyone ever swapped in a 5-speed?
Any one ever converted to a 5-speed?
I am thinking of using the drive train from my mustang in my project truck. ie. 351w backed by a 5 speed w/ a 9" and 4:11 gears.
Old Feb 14, 2004 | 01:21 PM
71swissaqua's Avatar
71swissaqua
Should be nice. I'm running a 351W with an AOD out of a Mustang with 3.73 gears. The gears get me off the line quick but I can run with traffic on the interstate and never bust 2ooo rpm's
Clint
Old Feb 20, 2004 | 09:33 PM
GT-Racer's Avatar
GT-Racer
input needed
Does any one know how much stuff I'd need to change as far as driveshaft length, clutch linkage etc?
Old Feb 20, 2004 | 10:50 PM
FE427TP's Avatar
FE427TP
probably both, didn't the mustangs use a pull type clutch? trucks are push, and I know with my toploader and TKO I had to have the driveshaft shortened when I put them in my truck
Old Feb 21, 2004 | 09:44 PM
GT-Racer's Avatar
GT-Racer
does the speedo still work?
Old Feb 22, 2004 | 12:08 AM
FE427TP's Avatar
FE427TP
yep, plugged right into the back of it and read within 2mph or so at 60 when I checked it against my GPS with my 4.10's, it will probably read different with different gear ratios
Old Feb 22, 2004 | 04:50 PM
GT-Racer's Avatar
GT-Racer
So how did you hook up the clutch?
couldnt I just weld a bracket on my pedal for a quadrant, similar to mustangs?
Old Feb 22, 2004 | 11:51 PM
FE427TP's Avatar
FE427TP
I have a FE so I just bolted it up to my bellhousing and went with it clutch linkage and all. I had to move the tranny crossmember back about 1 inch, but if I had used a car bellhousing which I'll swap to soon it would probably go into the factory holes. Oh yeah I couldn't use the bench seat but that was from the toploader and V-gate the TKO has several shifter locations so one could be made to work if you pushed it forward and found the right shifter handle, I used one from a mustang and a hurst **** and it fits just right for me and had to get a auto transmission tunnel cover which I used a cutoff wheel on and cut my own hole for the shifter
Old Feb 26, 2004 | 07:24 AM
svt522's Avatar
svt522
I swapped a late model truck 5-speed into my truck with the hydraulic clutch setup. It's been in my truck for two years and works great. I was going to use a T-5...the guts in the truck trans are a whole lot beefier than the Stang trans. The trans has a bad reputation but, my 20 year old neighbor couldn't break it in his F-150 and that was dumping the clutch with 35-inch mud tires. I've got it behind a fuel injected 5.0 Stang engine and have had no problems with it. Plus, the truck shifter ends up in the right place and is the right length compared to the T-5.
Old Feb 26, 2004 | 04:16 PM
averagef250's Avatar
averagef250
Sure you have a T-5?
The T-5's do not have the shifter in the right place at all. It will end up in the middle of your seat. Also, I could be wrong, but I'm pretty sure F-150's never used the T-5. Dumping the clutch in a truck would likely blow the hell out of a T-5. The trucks used a toploader tranny made by mazda. It's pretty tough, but if it ever breaks plan on taking a second mortgage as parts are outrageous. I owned a 91 f150 4x4 5.0 5 speed and couldn't kill that truck. I finally sold it and the tranny went out on the guy the next week. I got the tranny parts at cost and free labor for the guy through friends in the tranny business and he still had over $1000 in that tranny.
Old Feb 28, 2004 | 01:23 PM
svt522's Avatar
svt522
I have the Mazda M5R2 5-Speed in my truck. (Check out my signature.) I was refering to that tranny in my above post! That's the one my neighbor couldn't break! Dumping the clutch with a T-5 and 35" tires would spell grenade!
Old Mar 1, 2004 | 03:52 PM
GT-Racer's Avatar
GT-Racer
yes I know where a t-5 shifter is... but with buckets or a bench w/ a cut out the shifter will be near my hip. much better than that 4 foot pole by the dash. and I was using t-5 as a reference(meaning close ratio, not truck gears) I have already grenaded one t-5 behind this 351w, if i go this route it will most likely be tremec or something comperable.
stagecall
Apr 19, 2016 08:22 AM
1918ALF
Mar 7, 2016 05:01 PM
Handegard
Large Truck
Dec 14, 2010 09:55 AM
rotory.1
Oct 1, 2007 09:38 PM
bubbaredneck
15
Feb 13, 2002 07:57 PM
