Spools, mini or reg.
Old Feb 13, 2004 | 03:10 PM
yomow's Avatar
yomow
Hi, I might want a spool in my ride Question ? Mini or reg spool fit in a 9" rear ! how will a spool - when backing up is harder or will it back up OK ! Going in F-100 cc sb 390 stroked C-6 trans. Plan on using 3.91 gears or 4.11
Old Feb 13, 2004 | 04:52 PM
77'F-150Mudder's Avatar
77'F-150Mudder
Given the choices, I'd go with a full spool. There is nothing to break. With a mini you have the cross pin as the weak point. In the long run, the full spool will be more reliable.
Backing up won't be any different than going forward.
Old Feb 13, 2004 | 07:44 PM
yomow's Avatar
yomow
When backing up is it harderto backup or will it back up OK !
Old Feb 13, 2004 | 09:16 PM
Txquadhunter24's Avatar
Txquadhunter24
backing will be OK.....it'll be just like you put it in drive and go forward... the only place you'll have trouble is turning corners while driving. it'll squeel tires since both turning at same speeds.
Old Feb 14, 2004 | 08:47 AM
yomow's Avatar
yomow
squeel tires since both turning at same speeds. Sound's Great were do I sign up for Squelling tires . Heck I'm aready excited. !!!!
Do you know a good place to buy spools & gears.
Thank's, Don
Old Feb 16, 2004 | 09:31 AM
yomow's Avatar
yomow
Axle qustions will the axles hold up. 28 spline or 31 or will it make a diff.
Thank's Don
illinois4by
Jan 4, 2009 07:43 AM
oldhalftons
Offroad & 4x4
18
Jan 25, 2006 08:34 AM
Crazy Canuck
May 19, 2003 01:10 AM
big_country_ch19
Nov 27, 2002 01:27 PM
thatdude
Jul 12, 2002 09:53 AM
