Sponsored by: Kumho
mini spool
Old Nov 25, 2002 | 12:15 PM
big_country_ch19's Avatar
big_country_ch19
mini spool
ok what is a mini spool? I've never heard that term before. Jack
Old Nov 25, 2002 | 07:02 PM
Ford79's Avatar
Ford79
mini spool
A mini spool is a cheap way to lock your axles together. It replaces the spider gears in a differential with a splined "spool" that locks the rear (or front) axles together. They are easy to install and are not too expensive. Many people wouldn't run one on the street, but I've done so for a couple years without trouble.
Old Nov 25, 2002 | 07:11 PM
cek181's Avatar
cek181
mini spool
to all you guys that are running spools on the street, is it manageable to drive on the highway at about 70 miles an hour without too much trouble? im assuming it just involves getting a feel for it? do you just have to slow down going around corners and your pretty much fine? i know they arent reccomended but recommendations aren't made to be followed.
chris
Old Nov 25, 2002 | 08:07 PM
fordmaniac21's Avatar
fordmaniac21
mini spool
my spool does just fine on the street. it gets a little squirly on wet pavement. i havent had it in snow or ice yet seems i just put it in last spring. it takes a little bit of getting used to because the truck alwasy wants to go in a straight line. but all of it is worth it on the trail. you will be able to do stuff in 2 wheel drive that you had to use 4x4 for in the past. so i guess if you arent carefull you might get more stuck. but hey, thats half the fun of wheelin.
'75 F-100 4x4, 4" lift
35x15.5x15 super swamper TSL/SX
mini-spooled 9" rear end
390 w/ cam,headers,
and 4 barrell edelbrock
TRIED TRUE and FORD BLUE
Old Nov 25, 2002 | 08:45 PM
1984_355w's Avatar
1984_355w
mini spool
I was looking at my rear brakes the other day and my 9" rear axle on the '84 the pass. side moves in and out about a 32nd of an inch. Am I going to have to rebuild my axle?? Is the bearing just inside the diff. of not? I've been thinking of putting a mini or full spool on my truck as well. So if I had the do it this would be the perfect time. When you remove the 3rd member on the rear axle the gears and everything come with it right?? So you can take the member off and work on everything on your work bench correct?? That would seem like it would be really easy to put in a spool with the whole case, pinion, and gears removable. Or am I thinking about a different axle??
On the spool note I've heard the minis put more stress on the case and ring gear. Also does anyone know if my axles are 28 or 31 tooth??
Thank in advance
Old Nov 26, 2002 | 11:20 AM
Steve_Uzi's Avatar
Steve_Uzi
mini spool
If the mini is for your '84 F-150 4x4 that you have listed in your signature, then I am 99% sure its a 31-spline 9". I believe they only put the 28-spline 9" axles in the 2wd trucks, but Ford is weird like that. Both my 1984 and 1986 Broncos w/9" rears both have 31-splines axles.
Old Nov 26, 2002 | 02:34 PM
72f100's Avatar
72f100
mini spool
Mini spools are very easy to put in and are only around $30-40 for a 9". You will have no trouble what so ever on the highway but slowing down for curves is a very good idea. It makes the truck want to push (understeer) in corners unless it's slipery (rain or snow) at which point over steer can be a concern. If you are a knowledgable driver and know how to correct an oversteer skid as well as how to adjust your driving style to compensate for vehicle quirks you'll do fine w/ the spool. I wish someone made a spool for a 30 spline Dana60 cause I'd have one in my truck tomorrow. I drove on a mini spool for about a yr. or so before I put the truck on the highboy chassis and loved it.
Old Nov 26, 2002 | 06:46 PM
1984_355w's Avatar
1984_355w
mini spool
Thanks for the help.
I still don't know if I should go for a mini or full spool. I've heard mini's can but more stress on the cross pin and case and cause more deflection. I don't mine spending a hundred more if my diff. is gonna last 3 times longer.
Thanks
Old Nov 26, 2002 | 08:23 PM
fordmaniac21
mini spool
i havent had any troubles with my mini spool yet. i judt put the old cross pin back in my axle. i know that they make a stronger cross pin for use with a mini spool that isnt too expensive. i am gonna buy one soon before something bad happens to mine. and i dont think that i set my back-lash properly when i installed it. i had to replace the whole 3rd member when i did mine because it was cracked on the inner pinion bearing housing. you shouldnt have any troubles with it if you dont replace anything other than the mini spool for the side gears.
390 w/ cam,headers,
Old Nov 26, 2002 | 09:34 PM
fordtrck302's Avatar
fordtrck302
mini spool
does any one know if they make a mini spool for the ford 8.8 axle I have a 1991 f-150 4x4
Old Nov 27, 2002 | 07:22 AM
1984_355w's Avatar
1984_355w
mini spool
Go the jegs or summit
They have everything!!
Old Nov 27, 2002 | 01:27 PM
85 f150 4x4 302's Avatar
85 f150 4x4 302
mini spool
Four.on.the.floor
May 15, 2015 02:19 PM
gittinwidit
Jun 9, 2004 09:20 AM
thatdude
Jul 12, 2002 09:53 AM
KJKozak2
Mar 19, 2002 10:53 AM
mudbogger400
Offroad & 4x4
May 17, 2001 07:34 AM
