take off door ajar switch
Old Feb 13, 2004 | 11:55 AM
mountainman101's Avatar
mountainman101
on 1998 expedition .how to take door ajarswitch off latch assembly thanx.
Old Feb 13, 2004 | 02:33 PM
itlkick's Avatar
itlkick
If you search the archive there was a great post on how to do this. One thing I remember is if the reason for doing it is to keep your Expedition from thinking the door is open while driving - just spray some WD-40 in the locking mechanism of the door (from the inside where the lock hook is in the door - not the hinge). It fixed my Navigator - that problem bugged me for 2 years and a simple spray of WD-40 fixed it!
Old Feb 13, 2004 | 03:49 PM
Frizzle's Avatar
Frizzle
wd-40 fixed mine too
now all i need is a rubber stopper for the door which magically disappeared, anyone know the part #?
Old Feb 13, 2004 | 04:24 PM
msm718's Avatar
msm718
Re: take off door ajar switch
Hi mountainman,
I assume you already know how to remove the panel. Here are some directions I got from another member a while ago. I hope this helps you out.
1. After the door panel is off, you will need to undo the clips holding on the lock button rod and disconnect. Now the foam can be pealed back to allow access to the inside of the door. It is also a good Idea to remove the bulb from the courtesy door lamp.
2. Undo the bolt holding the window channel to the door frame, this is down on the left side of the door and there is only 1 bolt with no nut on the backside to drop. This will give you some room to work.
3. Mark with a marker the locations of the 3 adjusting rods for the lock, inside opening handle and the outside opening handle. Pop up the plastic clips usally yellow, red or white and remove 2 of the 3 rods, you might want to draw a sketch or take a picture of the orientation of these rods before removing. Be careful since these clips are plastic.
4. Unplug the 2 electrical connections from the latch assembley and unscrew the 3 black torx screws from the outside of the door where it latches to the door jamb.
5. Now with a little twisting and turning and pushing the window guide that we removed the bolt for earlier, you will be able to take the whole latch assembely out and replace the door pin switch that is on the bottom of the latch pointing up. Just push up and turn 45-90 degrees and it will come out.
6. reinstall in reverse order.
The part number we used was XF1Z10B987AA List price $11.25 check with the dealer to be sure this is the correct P/N.
ryanguglich
1978 - 1996 Big Bronco
21
Mar 14, 2011 06:31 PM
RBlanton
Nov 7, 2009 09:35 AM
Hometown Pride
13
Jun 1, 2009 11:02 AM
mat65
1983 - 2012 Ranger & B-Series
Jan 31, 2005 04:15 PM
lilman20815
Mar 6, 2001 08:36 PM
