93 Ranger (won't shift)
Old Feb 13, 2004 | 10:09 AM
jonranger's Avatar
jonranger
Question 93 Ranger (won't shift)
I've got a 93 Ranger with a 2.3L with 40K actual miles. Recently, it's been difficult to shift into gears, especially at a dead stop. The clutch fluid is full, and these are supposed to be self-adjusting clutches, right? At times its so difficult that the only way to get into a gear is by pumping the clutch. When this happens, the clutch pedal has no give, it simply sinks down the floor. Any ideas? I don't believe the clutch itself is going bad, because I don't experience any slippage. Any suggestions will be much appreciated.
Thanks,
Jon
Old Feb 13, 2004 | 11:16 AM
Lone_Ranger01's Avatar
Lone_Ranger01
Check your clutch fluid level. Sounds like the hydraulic pump isn't getting fluid or the pump may be bad. That is if it's a hydraulic clutch.
Old Feb 13, 2004 | 03:05 PM
CowboyBilly9Mile's Avatar
CowboyBilly9Mile
It's a problem in the hydraulics. Try flushing to remove all crud and dirty fluid then bleeding. After that, if it still does it, you need to determine if it's the master cyl (not too bad to replace ) or the slave cyl (grrrrrr, drop the tranny). You are correct about them being self adjusting.
BTW, if you have to add mucho fluid, check for leaks.
Old Apr 19, 2004 | 08:15 PM
L Charles's Avatar
L Charles
I couldn't get my 2.3 liter into first gear and it turned out to be shifter bushings. It worked like new after that.
But, I agree about the other explanations.
new2fordtrucks
Sep 24, 2014 01:41 PM
Iggy85
Jul 29, 2014 09:08 PM
RickTFL
May 16, 2014 07:04 PM
Sigma.40
Mar 15, 2014 04:22 PM
bamacountryboy
17
Nov 27, 2005 09:49 PM
