5.4 missing bad
Old Feb 13, 2004 | 08:30 AM
Robert L's Avatar
Robert L
5.4 missing bad
2001 5.4 triton motor in E 250 van. Runs great and then justd starts missing.....must get into gas to keep up speed. This may go on for an hour or more and then just clear up like nothing wrong. My mechanic cannot pull any codes. says there isn't any! This happens mostly at highway speeds but not limited to.Help please . Ive had fuel tank drained and fuel filter replaced.
Old Feb 13, 2004 | 02:08 PM
jambo's Avatar
jambo
I just had the same problem. all it was was the coil for #7 cylinder- runs fine now.
Old Feb 13, 2004 | 08:27 PM
mgoovaerts's Avatar
mgoovaerts
Sounds like a coil, typically only happening on 97,98s but if your the type to wash your engine a lot, water tends to sit on the coils. You can remove each one and look for greening/corrosion on the spring.
riverratba
Dec 22, 2013 12:03 AM
Downriver Thunder
Jul 14, 2010 01:50 AM
c487w
Modular V8 (4.6L, 5.4L)
Mar 28, 2005 08:58 AM
Mpotter
27
Sep 10, 2004 09:36 PM
Big-Red-Lariat
1997 - 2003 F150
May 17, 2004 05:55 PM
