1994 5.0 ?'s
Old Feb 15, 2004 | 04:28 AM
fastbigblockford's Avatar
fastbigblockford
1994 5.0 ?'s
getting ready to redo the 5.0L in my '94 F150, need a cam recommendation for use with stock injectors, TB, and so on. only mod to engine is headers and cat back single 3" w/40 series flowmaster delta flow. also, is this a factory hydraulic roller motor? not a big small block person, but not dropping a 460 in the daily driver, gas is just too outrageous. plans are re ring and bearing, (if everything specs out ok) and redo heads, (ie new springs, locks, retainers, some guidework if nesecarry) then add headers, and recam. want something that will help with low end torque, as this is a 3.55 geared 5 speed truck running 32's that sees alot of interstate, as well as some weekend trails. thanks for all the help.
Daniel
Old Feb 15, 2004 | 08:29 AM
jwtaylor's Avatar
jwtaylor
call comp cams for a recommendation, I have seen their extreme energy line compared against crane cams etc. and they did make a difference, on different simulated dyno graphs. 1-800-999-0853
Its my understanding that he HO motors were roller, and non of the truck 5.0's were HO, know thats not to say it isn't roller compatible, just means you have a flat tappet cam installed from the factory.
If it were lowend grunt I were after, then I would do the cam and 4.10 gears, just be sure of everything before you order the cam, as everything play a role in how the other reacts, being the cam is the mechanical brains, you want to get that last or at least pick which grind you plan to use after you have determined the rest of the drivetrain changes. Thats my opinion thought, Good luck with your project, later
Old Feb 16, 2004 | 02:51 PM
jimandmandy's Avatar
jimandmandy
The '94 is roller from the factory. Firing order is also not the same as earlier 302's.
With 32 inch tires you nead GEARS. No aftermarket cam is going to make a 302 feel like a 351 at low rpms.
Jim
Old Feb 16, 2004 | 05:33 PM
fordeverpower's Avatar
fordeverpower
some of the motors were roller and with 32 you have about 3.00 gears now. Call a manufactur and tell them of your plans and they will hook you up with a good choice for a cam.
Marko76
17
Mar 12, 2017 03:21 PM
kidkyle21
26
Sep 9, 2016 06:54 PM
Hankster1958
Exhaust Systems
Feb 29, 2016 10:00 PM
ClassicFordFan95
Feb 21, 2016 07:49 PM
Adam Spurgeon
Jul 31, 2015 08:33 AM
