power rear window cables
Old Feb 12, 2004 | 11:58 PM
furd4me's Avatar
furd4me
Question power rear window cables
93 explorer rear window needs fixing
Well it finally warmed up enough to "roll " the windows down today, and pop! the rear passenger window wont go back up. I did a search but most of the window issues seem to be with the fronts
I am guessing the motor assembly is different on the rears, no gears, just cable that is broken and all tangled amongst the drive pulley. Any advice on where to attach the cable ends when I buy a new one?...sorta figure the entire motor/cable assembly will need to be replaced as well as the nylon guide bushings but just couldnt quite see where the cable attaches (mirror and flashlight).
guess I could pull apart the other door to compare but thought someone might save me the effort.
any help is appreciated
Old Feb 13, 2004 | 06:06 PM
JerrySimm's Avatar
JerrySimm
The cable and metal assembly is called a window regulator. I had to change the rear drivers side in my '92 explorer. I suspect it is probably the same as a 93. The regulator is only available from Ford and the motor is seperate. My motor was fine. If you change it, the one odd thing you'll need to get is a 1/4 inch pop rivet kit. The 1/4 inch pop rivets can be difficult to find, but some car parts places have them.
cstanley44
31
Feb 28, 2019 08:38 PM
Pm1250
Feb 24, 2016 12:40 PM
IdahoGoodhome
2009 - 2014 F150
Aug 12, 2015 06:56 PM
Club Wagon
33
Sep 27, 2013 11:20 PM
WiNgRg
Mar 9, 2010 05:03 AM
