transmission swap
Old Feb 12, 2004 | 11:32 PM
Rocky Ranger's Avatar
Rocky Ranger
Arrow transmission swap
What transmission will bolt up to the 300 straight 6 and be better than the granny gear 4 speed
Old Feb 13, 2004 | 03:59 AM
RTM's Avatar
RTM
A ZF.
Old Feb 14, 2004 | 09:53 AM
78fordman's Avatar
78fordman
What do you mean by better than a granny 4 speed, in my book there is nothing tougher. A ZF is a step down from a T-18 or a NP 435. If you want overdrive then you can swap in a ZF or get an over-under drive unit.
Old Feb 14, 2004 | 10:26 AM
HD F150 SC's Avatar
HD F150 SC
i'm with you rocky, i just got ahold of an '89 that my old company i used to work for had and this thing has been a real piece of crap. i just put a new clutch in it and the throw out bearing is crying to get back out of there. this tranny has made all kinds of racket since brand new and this is the 8th clutch set in 253,000 miles. i'm not sure what it would cost to rebuild it, but i'm wondering if it would be possible (and easy) to swap in a auto. anyone here know?
chuck
Old Feb 15, 2004 | 11:04 AM
78fordman's Avatar
78fordman
You could swap in a C-6 pretty easy, but the electronic ones will take some customizing. Or maybe an AOD.
Old Feb 15, 2004 | 11:41 AM
HD F150 SC's Avatar
HD F150 SC
tell me more fordman, i'm very interested in using this borg-warner as a trot line anchor. any specific years i should be looking for? do you know if there are any aftermarket floor shifters that can make the hook-up? i guess my best bet would be to find a junk truck and utilize all the parts off of it.
Old Feb 15, 2004 | 12:06 PM
78fordman's Avatar
78fordman
Well they are all pretty much the same throughout the years. The NP 435 is a little more lasting, but the T-18 is still a very tough tranny. They cam in 72-79 4 speed trucks. The T-18 has a cast cover, as where the Np 435 has aluminum covers. I have not found any aftermarket floor shifters. 2wd and 4wd trannies have different length tail shafts, so get the correct one to start off with. I junk truck would be the best bet, because you might need to move the crossmember for the tranny support, i do not know.
hermannm2
2009 - 2014 F150
Jul 16, 2016 12:51 AM
firefighter7520
Dec 17, 2007 12:07 AM
IES
Nov 20, 2002 12:20 AM
jim henderson
Apr 16, 2002 02:13 AM
furchtlos
Apr 23, 2001 05:37 PM
