Sponsored by: Kumho
Gearing
Old Feb 12, 2004 | 10:32 PM
BudArnold's Avatar
BudArnold
Question Gearing
Hey guys, wondering what you might think here.
Going to be running 325/80R16's with 16x10 rims on a 67-72 F250 4WD. they come usually with 4.11's but i will be doing alot of freeway driving with some heavy towing at highway speeds and some mild off-roading. should i go up? if so, how high should i go? i was thinking 4.56's front and rear, what do you guys think? higher? lower? i am not too worried about gas mileage (who is with these bad boys???) I don't, however, want my RPM's skyrocketing when i am cruising down the freeways at 75 mph. Any ideas???
Old Feb 12, 2004 | 10:33 PM
BudArnold's Avatar
BudArnold
Just FYI (i just figured out this dang metric tire system myself!) the 325/80R16's equal roughly to 37x13.50R16's. any light you guys could shed would be more than welcome!!
Old Feb 13, 2004 | 01:08 AM
SoCalDesertRider's Avatar
SoCalDesertRider
Iwould go 4.56 or 4.88 with 37's, 4.88 if you will be towing. You want an equivalent ratio to 4.10 with stock tires for towing. Go to www.ring-pinion.com to use their calculator for tire size/gear ratio/rpms. Stock tire size is probably ~31".
Aerostottle
Aerostar
18
Jan 17, 2017 12:58 PM
olds68cutty
Apr 24, 2013 09:29 PM
70_F250_390
Oct 24, 2011 04:25 PM
Grant N.
Oct 18, 2009 09:13 PM
bansheeboy182
Oct 13, 2002 10:44 PM
