West Coast Bronco:
bob arrington is right to a point. You can get to the wiring that way but if you need to get to the rest of the wiring in the quarter pannel you need to remove your driver's side tail light. That is where the plug is located. From there it goes down under the truck and follows the frame (somewhere) I do not know where yet as I am having the same problem with my gate glass and the outside switch.
Hope this helps
