1965 light bulbs
Old Feb 12, 2004 | 03:23 PM
yomow's Avatar
yomow
1965 light bulbs
My 1965 F-100 cc Short Bed Dash lights ??? Had 1895 bulbs in dash installed t293 bulbs . I would like brighter lights in my dash . Any help is needed !!! Also I don't mind changing out for diff. sockets, also Brighter tail light bulbs 1157 in there now !!!
Thank's, Don
Old Feb 12, 2004 | 05:52 PM
BobbyFord's Avatar
BobbyFord
Not too sure about the dash bulbs, but I believe 2157's are brighter for the tail lights. There are also LED replacement bulbs available for the rears, too.
Old Feb 13, 2004 | 05:09 AM
jowilker's Avatar
jowilker
Hi Don, Try putting in new bulbs in the dash. The old bulbs get dim over the years. Make sure your grounds are good to make the tail lights brighter.
John
Old Feb 13, 2004 | 07:53 AM
yomow's Avatar
yomow
Checked , Ground's & replaced bulb's already . I found socketsfor 194 bulb's any brighter bulb's for it ??? I will check on 2157 bulb's today
Thank's Don
Old Feb 14, 2004 | 07:47 AM
Tedster9's Avatar
Tedster9
Dim lights means high resistance somewhere, make sure all those pin connectors are clean and bright, there's a dozen or so all over the truck, plus ground connections. WD40 or contact cleaner and bristle brushes will perk things up. If you can see corrosion (green powder) than they will soon fail.
Downriver Thunder
Dec 6, 2006 03:08 PM
nickmobile67
Electrical Systems/Wiring
Jul 31, 2006 11:14 AM
Carnivore
2004 - 2008 F150
Apr 7, 2004 01:04 PM
Hit Man X
Sep 19, 2003 03:12 PM
