where do u go to find out what the timing setting needs to be?
i thought it was on the emissions sticker. but i was wondering if there was another place i could get it. and if not where could i get a new emissions sticker?
my 390 has a sticker on the outside of the driver's side valve cover...i think it says 6 BDTC, but my 390 runs better when it is set at 12 BTDC. Somewhere in there should be fine, just experiment and see where it runs best without pinging.
sop hmmmm military huh anyway yeah most trucks run best between 8 and 12 if its still all stock dont be suprised if it is off a litttle bit more the balancer is probbably old and may be starrting to slip.
I am a little confused. I did find the marks on the balancer, but it looks like the weight has been removed. What is on it looks like a pulley, with about a little over a quarter in of balancer behind it. When I felt behind it I could feel rubber, making me think that its not all there. Not sure what I have or need here. Did balancers come that skinny? The Block is marked D4TE-I. I was told its a 69 360, but it doesn't add up? Any ideas gentlemen? Thanks
