Replacement emission sticker?
Old Feb 29, 2016 | 04:19 PM
jochiu's Avatar
jochiu
Hi, I have a 1978 Ford F250 supercab with the 400 engine and getting someone to smog it is really hard because it's missing the emissions sticker and because they see the truck has no cat no evap so they kinda think it's an undercover vehicle. I eventually found an old timer who was willing to smog it but I was wondering where would I find the emissions label for it, the part number is D8TE 9C485 ACA so it would be easier to find a smog tech who is willing to smog it.
Old Feb 29, 2016 | 11:06 PM
dads1977's Avatar
dads1977
jochiu
Welcome to FTE
You shouldn't "have" a problem smogging your truck here in the communistic country of Ca, as long as you have all the components that truck came with unless it was fed built sold truck,
You could ask your smog shop for a diagram so that you can double check before you have it tested...
I thought I was going to have an issue smogging mine after I rebuilt my motor but my smog shop gave me a diagram they had and it passed due to having the parts WITHOUT
the "Vehicle Emissions Control Information" decal
Have you tried looking at the online catalogs for NPD,Dennis Carpenter,Bronco Graveyard yet? you might get lucky and find one close ....enuff
Old Feb 29, 2016 | 11:28 PM
jochiu's Avatar
jochiu
My truck isnt a california certified it's a federal certified and many shops in San Francisco won't touch the truck because it's too big and they can't tell if it's a California or federal truck. Many of the techs don't know what they are looking at so they claim that it's been tampered with but if they look up the diagram that's how a federal 400 came from the factory. I tried all the online sites and they only have 1977 400 stickers
Old Feb 29, 2016 | 11:52 PM
HIO Silver's Avatar
HIO Silver
Try Dearborn Classics.
If that doesn't work out, consider trolling the salvage yards like Pick N Pull for a 78 valve cover... it's worth a shot.
Install it for your biennial test/inspection and afterwards stick it back on the shelf.
Old Mar 1, 2016 | 09:05 AM
54Hydro's Avatar
54Hydro
Does your pickup have the large gas filler or does it have the baffle at the inlet to only accept the unleaded pump handle? If it has that baffle it was built to run unleaded and probably had a cat. Leaded gas and catalytic converters didn't mix. That might help you prove your case.
Old Mar 1, 2016 | 10:20 AM
jochiu's Avatar
jochiu
My truck does have the large filler on both tanks
Old Mar 1, 2016 | 12:43 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
I eventually found an old timer who was willing to smog it but I was wondering where would I find the emissions label for it, the part ID Engineering number is D8TE 9C485 ACA so it would be easier to find a smog tech who is willing to smog it.
Stickers could only be ordered by Ford dealer parts guys from FoMoCo with registered owners name and the VIN. None are available today.
DSO code (stamped on 3rd line-far right of Warranty Plate) for sold new in CA Ford (not L/M) cars/trucks: 71 = Los Angeles (SoCal) / 72 = San Jose (NorCal). Any other code is non CA
Old Apr 10, 2021 | 09:13 PM
Jerry5533!'s Avatar
Jerry5533!
78 f150 decal found on ebay for 10 bucks
Is this what your looking for? Found it on ebay for 10dollars shipping is extra.you can also go to a printing company that makes signs they can make one for you, or a friend who knows Adobe photo shop.
Old Apr 10, 2021 | 10:48 PM
John89's Avatar
John89
Check ebay and parts/specialty catalogues.
I think Dennis Carpenter may have some.
NPD, MACS, classicautoparts.com are a few.
I also found one on eBay for our 300. Before I put it on, I took it to a local print shop and had about 10 made to resell.
SpectreZ91
Feb 24, 2006 01:28 AM
Droberto05
21
May 2, 2004 05:47 AM
Crumm
20
Oct 26, 2003 11:01 PM
cleveland short
Sep 14, 2002 12:47 AM
86F250
Exhaust Systems
Jan 16, 2002 10:04 PM
