Sponsored by: Auxito
Squeak!
Old Feb 10, 2004 | 10:15 PM
Mr J's Avatar
Mr J
Exclamation Squeak!
What the hell is this? When I put it in gear (f or r) it makes a funny squeaking sound. (not unlike Christmas vacation) I have jumped up and down on the bed so I can assume it's not the shocks. What is it? u joints? rearend? no other probs.
Old Feb 10, 2004 | 11:19 PM
LxMan1's Avatar
LxMan1
Fan belt slipping?
Old Feb 11, 2004 | 08:03 AM
jimford1's Avatar
jimford1
I just had the same problem with my ranger. Does it start sqeaking when you move or at idle. If its when you move then I would think its your U-joints. But my truck sqeaks when I start it. Ever since I went through some deep water. I actually think it might be bearings in one of the pulleys. I hope not though!
Old Feb 11, 2004 | 09:37 AM
Mr J's Avatar
Mr J
It starts when I move. When I am moving, I can hit the throttle and make it do it also. Real annoying. Not the belt, though. Definately coming from the back end.
Old Feb 11, 2004 | 01:03 PM
jimford1's Avatar
jimford1
I would say it is definitely your u-joint. Have you ever done them yourself. They are real easy to change! I have had the same problem with my old 83 GMC stepside that I had. Fixed them on the lift at the garage my father works at. Took me about 45min.
Old Feb 11, 2004 | 02:24 PM
JeremyH's Avatar
JeremyH
A definite was to tell if it is teh u-joint or not is that they will only squeak when the vehicle is in motion and will increase in frequency as the vehicle speeds up.
I'd start here and pull the driveshaft and grease the u-joints.
Something common that also squeaks is the idler pulley.
Old Feb 11, 2004 | 04:00 PM
Mr J's Avatar
Mr J
yeah, I've done u joints before on an older ford. but I've got my buddy haynes to help me. It also happens a lot when I go over bumps. I realize that trucks are aren't supposed to ride like mercedes, but anyone got some good suggestions for shocks that will keep my kidneys from gettin bruised? Bilstein, edelbrock, rancho....etc. Which ones are smoothest. I've got 91000 and the shocks are stock. Keep in mind, I've got the air ride as well. Any sugg.?
AlexGardnerf-250
Dec 13, 2013 08:35 AM
spdmpo
13
May 28, 2010 10:17 PM
naiku
1997 - 2003 F150
Aug 11, 2006 08:19 AM
Saguaro_7.3
Nov 7, 2005 10:52 PM
spoon059
Mar 5, 2003 08:39 PM
