Offroad & 4x4
Off Roading Technique
Old Feb 10, 2004 | 03:52 PM
RawPower's Avatar
RawPower
Do you thuink it is better to go into a mud hole in 4x4, and engage the other mods as you need them, or to go in in 4x4, lockers locked, etc.?
Old Feb 10, 2004 | 04:45 PM
Idiomaticman's Avatar
Idiomaticman
well, if i had doubts about getting though to the other side without everything locked up i would definately lock up. when in mud holes it is nesicary to have momentum, and if you have to stop and lock everything up right in the middle of the hole, you have just put yourself in a bad situaltion and are likely not to get out anyway.
Idiomaticman
Old Feb 10, 2004 | 04:57 PM
MustangGT221's Avatar
MustangGT221
Well with my ARB I can engage it as long as there's no torque on the axle or different speeds between the front tires. If I go into a mud hole that I don't think I can get through easily in regular 4wd, I lock it, mash the gas, hit the mud hole and hang on
Old Feb 10, 2004 | 05:14 PM
red_rocket's Avatar
red_rocket
I just lock my hubs when I hit the trail. My axles are always locked whether I need them to be or not.
Old Feb 10, 2004 | 05:29 PM
Munkey's Avatar
Munkey
Lock hubs as soon as you leave the pavement, air down, plan route of attack, and lock diffs before going in. It's no fun to be sitting in the middle of the hole swearing at yourself because you got stuck!
Old Feb 10, 2004 | 07:40 PM
rlh's Avatar
rlh
Your not really supposed to engage things when wheels are spinning whether its 4Lo or engaging a locker. You should be ready when you hit the mud with momentum. If you are in a chevy call a tow truck in advance and if you are in a dodgie, pray.
Old Feb 10, 2004 | 10:49 PM
SoCalDesertRider's Avatar
SoCalDesertRider
yeah once you start, don't stop! Get all the ducks lined up ahead of time and go in shooting with both barrels.
Old Feb 10, 2004 | 11:02 PM
fishmanndotcom's Avatar
fishmanndotcom
same here! it all depends on the mud hole! I know i can make most holes around here in 2wd so i normally don't need but one hub locked, but if it looks hairy i go ahead and lock both!
it's all in what you are about to tackle!
-jason-
Old Feb 11, 2004 | 12:48 AM
85351ho's Avatar
85351ho
Re: Off Roading Technique
lock it all in and Floor It !!!!!
Old Feb 11, 2004 | 12:51 AM
Pentekno2's Avatar
Pentekno2
Don't floor it if the situation doesn't call for it. There nothing worse than trying to get yourself unstuck with a busted Dana 60 Axle shaft, or possibly worse - Ive seen it too many times to condone it.
-Pentekno2
Old Feb 11, 2004 | 09:28 AM
fishmanndotcom
-Pentekno2
dude....carnage is cool
-jason-
Old Feb 11, 2004 | 11:01 AM
ivanribic's Avatar
ivanribic
Hahaha. When in doubt . . . power out. If your axle shaft breaks it's time to replace it with something stronger.
Worst think people can do is STOP in the middle of a mud hole.
Old Feb 11, 2004 | 11:32 AM
rebocardo's Avatar
rebocardo
I agree 100% with Idiomaticman.
Old Feb 11, 2004 | 03:09 PM
RawPower's Avatar
RawPower
I concur.... with some of the stuff. Most of the mud holes I hit, Ive hit before, so I know what I need to engage and what not to engage.
Oh, thanks for telling me to get out and engage the hubs before, I never thought of that one....
Old Feb 11, 2004 | 04:58 PM
proeliator's Avatar
proeliator
Why is this even a question !? Lock everything you got up once you leave the pavement, aim, shoot, and nail the skinny pedal.
