Lift?
Old Feb 10, 2004 | 01:33 AM
morrijg83's Avatar
morrijg83
Lift?
I have a 92 f250 4x4 i cant decide if i want a 6 or 4 inch kit with 35 or 36. i cant seem to find many on the street that are 250's if anyone has any input i would appriciate it
Old Feb 10, 2004 | 08:40 AM
Ford64Life's Avatar
Ford64Life
I would go with a 4 inch lift. its a little less radical and 35s should fit. I believe 33s will fit stock so you should be fine.
Old Feb 10, 2004 | 05:15 PM
Lou Braun's Avatar
Lou Braun
As mentioned, a 4 inch lift will allow you to run 35" tires OK. If you plan to flex your suspension to the limit, then 33's would be a better choice.
If you go with a 6 inch lift, you will probably want to replace the front driveshaft with one that has a CV joint at the transfer case. Shafts from an F-350, along with the F-350's output yoke might work for you.
Skyjacker makes a decent kit for your truck. Superlift is another good one.
Lou Braun
Old Feb 11, 2004 | 05:46 PM
Blue Rage's Avatar
Blue Rage
I have a 1991 F-250 with a 6 inch lift on it using the stock drive shaft. I was able to fit 38's under it with no body lift! 36's will look a little better with the 6 inch cause they won't be stuffed like mine. But with the 6 inch, you really should get extended braided brake lines.
Old Feb 13, 2004 | 05:26 PM
sleepysal's Avatar
sleepysal
My 92 4X4 F250 X cab long bed has a 4 " trailmaster lift and 295 75 16 nittos,and it sits fine. I want to put 315 75 16 but it has 3.55 gears, so untill I can afford to swap to some 4.10 she 'll run the 295's
Eggs2bacon
Feb 8, 2017 02:09 PM
Cactusjack01
Jul 11, 2016 07:32 PM
kjf-250
Sep 6, 2010 08:08 AM
strokinout
Feb 24, 2010 07:53 PM
tooltime23
Jun 22, 2003 10:42 PM
