Sponsored by: Auxito
Gear Question
Old Feb 9, 2004 | 11:14 PM
FordCowboy2000's Avatar
FordCowboy2000
Question Gear Question
Hey ya'll I was just wondering something.....here is what I have in store for my truck:
1) 6 inch Skyjacker lift
2) Going to 17 inch wheels
3) Running 37 inch BFG AT's
I just want to know wether or not I have to change my front and rear gears...if so what type gears should I go with? Thanks for all the help.
- - Cowboy
Old Feb 10, 2004 | 08:58 AM
JeremyH's Avatar
JeremyH
You dont have to change your gears, but I would highly recommend that you do. Look here for gears.
Old Feb 10, 2004 | 09:33 AM
CONTRiC's Avatar
CONTRiC
<https://www.ford-trucks.com/forums/a...ic/135020.html>
Good archived post on gearing in general.
You should only regear if you want better response and better gas mileage (tongue in cheek)
Old Feb 10, 2004 | 02:56 PM
freak98's Avatar
freak98
I would go with 4.56 gear's.I have 9 inches of kift and 35's on my 98 F-150 and these are what I went with.
Old Feb 10, 2004 | 08:13 PM
Racerguy's Avatar
Racerguy
On my old F250 I had 38.5" Ground Hawgs on it and went with 4.56 gears. I had a 428CJ in it though so I had lots of power. Later I replaced that with a 351W and it was marginal for power. I think with the smaller engine that 4.88s would have been better.
Cowboy do you know what gears you have now?
Old Feb 10, 2004 | 09:15 PM
FordCowboy2000
Racerguy,
Not too sure what gears I have...how do I check? Thanks.
Old Feb 10, 2004 | 09:33 PM
MilitaryMan4X4's Avatar
MilitaryMan4X4
They should be 3.55, as most of them are (mine are)...but someone will correct me if im wrong, thats something you can always be sure of in this forum
Old Feb 11, 2004 | 12:28 AM
CPerry's Avatar
CPerry
Look at the axle code on the sticker in the door jamb or look at the tag on your rear end for the gear ratio.
Old Feb 11, 2004 | 01:00 AM
FordCowboy2000
Ok all here it is :
I do have 3.55 gears right now.
One last question, do you think that my truck with the 4.6 can handle going as big as I am thinking? I dont want to burn her out. If not, how big do ya'll think I should go while keeping the "big and mean" look. Thanks for the help ya'll.
- - Cowboy
Old Feb 11, 2004 | 10:51 AM
CPerry's Avatar
CPerry
I think 35's and a 6 inch lift would still give you the "look" you are going for and will not put too much strain on the 4.6l.
What was your stock tire size? if they were something like 235/75 16's (29" diameter), you may still want to go with 4.56 gear. If the stock tires were taller, you may be able to get away with 4.10's.
Old Feb 11, 2004 | 11:54 PM
FordCowboy2000
stock tire size were 255/70 I was thinking bout going with 4.56.
- - Cowboy
mrdoughnut
Modular V10 (6.8l)
Sep 8, 2011 10:35 PM
nordvik72
Apr 18, 2011 03:29 PM
hatchet
Offroad & 4x4
15
Aug 12, 2007 09:16 AM
Shanemh
Jun 13, 2007 03:00 AM
code3k9
Jul 18, 2003 07:40 PM
