Sponsored by: Real Truck
gears
Old Jul 17, 2003 | 01:24 AM
code3k9's Avatar
code3k9
gears
I have a 03 v-10 4x4 crew cab 8 inch fabtech with 38 inch tires. The gears in it are 355's now what whould be a good gear to go with. I really dont climb much, but my acceleration is pretty bad.
Thanks
Old Jul 17, 2003 | 01:35 AM
ddrummer's Avatar
ddrummer
gears
With 38" tires you are roughly 8" bigger in diameter or about 25% bigger than the stock tires. This means that your actual power to the road is about 25% less. There are a lot of calculators on the web to tell you what gear ratios get you back to the same power at the pavement ( www.ring-pinion.com ). Remember though, you can't beat mother nature. You'll get power and acelleration back, but you'll lose top end speed.
ddrummer
Old Jul 17, 2003 | 02:14 AM
dgodude's Avatar
dgodude
gears
Code3k9,
I have the same set up as you. This past weekend I changed the gears on my truck from the stock 3.73 to 4.88, much better response and power.
I was debating between 4.56 and 4.88 gears. I decided to put the 4.88, just in case I decide in the future to put bigger tires and lift.
Stock tires on a F250 with 3.73 is almost the same RPM as with 38 in tires with 4.56 gears.
Hope this helps.
Roger.
2002 F250 V10, 4x4, 4.88 gears
8 in Fabtech lift
38/15.5/16.5 Super Swampers
KNN FIPK
SCMT
Dual Sport Gibson Exhaust
Old Jul 18, 2003 | 01:10 AM
code3k9's Avatar
code3k9
gears
How is the speedo now? How much was it? thanks
Old Jul 18, 2003 | 10:49 AM
RRMike's Avatar
RRMike
gears
I don't think re-gearing will help the speedo.
Old Jul 18, 2003 | 07:40 PM
DCSpecial's Avatar
DCSpecial
gears
I don't think regearing effects the speedo either.
Look into the Superlift Truspeed module to do that.
If you really wanted to you could probably even run 5.13s.
Depends on what 38" tire you have to get a more accurate measure of the change to the effective gear ratio of your truck.......i.e. 38" TSLs are almost an inch smaller than a 38" PJ...and when calculating the change in RPMs every inch counts.
Hope this helps.
renyren
25
May 8, 2018 12:41 PM
86 FORD GUY
Nov 21, 2013 09:07 AM
mrdoughnut
Modular V10 (6.8l)
Dec 23, 2011 03:10 PM
mrdoughnut
Modular V10 (6.8l)
Sep 8, 2011 10:35 PM
green250
Modular V10 (6.8l)
Feb 7, 2010 11:03 PM
