If it's the a4ld
possible causes:
1. Improper fluid level
2. Manual linkage misadjusted/damaged
3. Low main control pressure in reverse
4. Reverse clutch assembly burnt/worn/leaking check ball in piston/keaking piston seal rings.
5. Valve body bolts loose/ too tight
6. Valve body dirty/sticking valves
7. Tranny fliter plugged
8. Pump damaged
9. Low/reverse servo piston seal cut/leaking
Wolffpax, FWIW that automatic actually wasn't the one in the 84 B2, that was the C5.
Ozzie - does the shifter appear to be engaging reverse but you get nothing when you let out the clutch, or what exactly? For future reference, you have a Toyo Kogyo 5 speed transmission (TK5).
Originally posted by fastpakr Wolffpax, FWIW that automatic actually wasn't the one in the 84 B2, that was the C5.
fastpakr, the shifter engages, but when you let out on the clutch, I get nothing.
