Rear brake locking up in reverse
Old Jan 5, 2014 | 08:17 PM
84FordTruck's Avatar
84FordTruck
So I got an 84 f250 and when I go into reverse the passenger side drum brake locks up. I can go forward just fine it's only when going backwards. I replaced the drum, shoes and got a new hardware kit and it still does it. I also disconnected the parking brake spring inside the drum but the problems still there. Any ideas what it could be.
Old Jan 5, 2014 | 08:23 PM
Franklin2's Avatar
Franklin2
Make sure the long shoe is to the rear, the short shoe is toward the front.
Old Jan 5, 2014 | 08:47 PM
ctubutis's Avatar
ctubutis
Yes, only thing I can think is that something got assembled wrong.
Old Jan 5, 2014 | 10:26 PM
84FordTruck
I thought I had them in right but I'll check again tomorrow. Anything else I should look for while I'm over there?
Old Jan 6, 2014 | 03:15 AM
oneowner83's Avatar
oneowner83
Did this problem occur on its own or after you had it apart (for a brake job perhaps)?
Old Jan 6, 2014 | 12:36 PM
84FordTruck
On its own thats why i started replacing everything.
Old Jan 6, 2014 | 03:20 PM
bill06447's Avatar
bill06447
Do you have a loose wheel cylinder or backing plate? Common cause of what you describe. ~Bill
Old Jan 6, 2014 | 10:59 PM
FordFETruck's Avatar
FordFETruck
Check for sicking wheel cylinders, they can sometime cause problems like that.
Old Jan 7, 2014 | 05:30 PM
bill06447's Avatar
bill06447
Been thinking about this all day-did you pull the drivers side drum to make sure that side is actually operating correctly/adjusted properly? Other side is gonna lockif one isn't working... ~Bill
Old Jan 8, 2014 | 11:23 PM
84FordTruck
I haven't checked the other side yet didn't think that would make a difference but that's good to know I'll check that side out next chance I get. The other day I also checked out the shoes to make sure I had them on right, turns out I didn't but I fixed that and the problem is still there. Thanks for all the input guys I appreciate the help
Old Jan 8, 2014 | 11:55 PM
Brnfree's Avatar
Brnfree
Can the drum be out of round, need turning / replacing?
If you can, put it on jack stands and take the drum off the driver side so that you can compare everything with the passenger side.
Old Jan 9, 2014 | 12:08 AM
84FordTruck
The drum is brand new. Hopefully tomorrow I'll get the chance to check out the other side
rolloman
1997 - 2003 F150
Jun 14, 2020 11:44 PM
BuickTurbo
17
Jan 27, 2007 06:11 PM
bryan_johnson
Dec 29, 2004 09:16 AM
Wask
1983 - 2012 Ranger & B-Series
Mar 10, 2003 05:35 PM
jared
Oct 6, 2000 02:51 PM
