HELP! Spark knock!? Changed air intake
Old Feb 10, 2004 | 02:15 PM
hallboy's Avatar
hallboy
Lightbulb reset computer
Exlporereddieb.
I disconnect every time I do something to the engine including changing the plugs.
I don't however turn the lights on or anything like that. I will try it and let the battery sit over night tonight.
Old Feb 10, 2004 | 05:42 PM
maa139's Avatar
maa139
Originally posted by hallboy
maa139: I don't know how to pull codes!?! I have run a carbon cleaning system. I cleaned MAF when I did the filter swap. I have NOT replaced the filter or torqued the lower intake bolts. I will try that as well. Keep in mind this all happened after switching the filter.
You can either go to autozone - they will pull codes for free for you. Or, you can use a paper clip and watch the CEL flashing. There are posts here that describe how to do that, or a haynes manual will also have the procedures. If it just started after changing the air intake, I'd start with cleaning the MAF and resetting the computer.
Matt
Old Feb 11, 2004 | 08:08 AM
hallboy's Avatar
hallboy
I have throttle body spray. I think it will work for the MAF. I will let it sit for an hour or so off the batt and see what happens.
By the way. If anyone wants to see what this thing looks like you can look at my gallerys.
Old Feb 11, 2004 | 12:48 PM
hallboy's Avatar
hallboy
Thumbs up Thanks to all!!!
Thanks to eveyone that gave advice. After many different things it is finally gone!
I replaced the plugs, cleaned the throttle body, cleaned the MAF, ran a hose from the vac tree to the intake tube and finally disconnected the battery for about 3 hours.
I test drove this morning and it appears to be gone. I'm sure this will help my fuel and save me from more trouble latter down the road.
Again, Thanks to everyone who helped out. This is an awesome site
Old Feb 11, 2004 | 02:34 PM
maa139's Avatar
maa139
Let us know what happens to your milage...and glad we could help!
Old Feb 12, 2004 | 12:45 PM
96explorereddieb's Avatar
96explorereddieb
Congrats!! I'm sure you will get at least a couple extra miles a gallon now. I'll be adding my own FIPK too and I'll see if I can get up to 20mpg on the highway.
Old Feb 12, 2004 | 05:42 PM
hallboy's Avatar
hallboy
FIPK
Explorereddie,
Old Feb 12, 2004 | 05:45 PM
hallboy's Avatar
hallboy
explorereddie,
sorry about the last blank reply.
you know ofcourse you can buy a nice kit for $150+ but this entire set up cost me less than $30. I can give you pics if you like and now I think there is a piece you can buy that will even make it easier.
Good luck.
Old Feb 12, 2004 | 05:47 PM
96explorereddieb
I bought it used for $40. It was only used for a year so it's a great deal!
Old Feb 12, 2004 | 07:32 PM
hallboy's Avatar
hallboy
Thumbs up $40!!
That is a sweet deal for sure!
Just remember to disconnect the batt for awhile before test driving.
Old Feb 12, 2004 | 08:52 PM
96explorereddieb
Will do!
Old Feb 15, 2004 | 07:14 PM
96explorereddieb
Welp...installed it over the weekend. Here's a pic:
Had a little trouble installing it because of missing bolts and nuts to attach the MAS and the filter adapter but $0.26 and 4 new bolts, nuts and washers later, it's installed. It's a lot louder and has a lot better throttle response. And it's only $40!!! I love it!!!
Old Feb 15, 2004 | 08:41 PM
  #28
hallboy's Avatar
hallboy
Thumbs up new intake
Billy,
Looks great! You should get even better responce in a couple of weeks when everything levels out.
SWEET
Old Feb 16, 2004 | 02:29 PM
  #29
96explorereddieb
Sweet!! I can't wait to drive it this weekend!!
JEFFFAFA
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
22
Jun 2, 2015 07:31 PM
bigcountry25
2004 - 2008 F150
May 6, 2014 12:14 PM
Jeff Dodson
Oct 9, 2009 06:47 AM
lobsterboy
Dec 31, 2003 10:51 AM
