FE Intake
Old Feb 8, 2004 | 11:01 PM
BigCrzyRdNeck's Avatar
BigCrzyRdNeck
FE Intake
Yes I am building a 360-390 and doing away with the stock 80lb cast iron 2 barrel intake and I am trying to find a good used or new don't care which just price matters a dual plane 4 barrel aluminum intake I will take any help given . Thanks
Old Feb 9, 2004 | 07:23 AM
fordman428's Avatar
fordman428
a edelbrock performer intake would work fine, or the edelbrock performer RPM if you even plan on hopping it up.
Old Feb 9, 2004 | 11:11 AM
gtex's Avatar
gtex
I can't quite tell from above, is price a concern?
If so, there are some older Ford Aluminum intakes that can be had for much less than the Edelbrock products.
I'm not sure of the part numbers. I'm sure one of the Gurus will check in shortly.
Old Feb 9, 2004 | 08:22 PM
fordeverpower's Avatar
fordeverpower
the edelbrock performer is probally the best choice for trucks.
Old Feb 10, 2004 | 07:19 AM
BigCrzyRdNeck
Yea I'm only hoping up on the turqe sid because I haul a tractor and other heavy loads on the farm.
Old Feb 11, 2004 | 12:23 AM
Jobless's Avatar
Jobless
I ran into a bit of a problem with the 1st Edelbrock performer 390 intake I installed. It seesm as though they machined the distributor hole off center so badly that the distributor would not even slide down into the motor.
Summit was more than happy to replace it with another after they contacted Edelbrock and they told him that yes this was a problem they were aware of.
I got the 2nd intake installed and even though the distributor now fits in the hole it is still off center enough to cause the rubber seal not to make 100% contact all the way around the distributor....it will probably leak oil with out a good coat of RTV.
Old Feb 11, 2004 | 12:54 AM
fling's Avatar
fling
Hows that F350 pull that tractor? How does it sound with the twin stacks?
Old Feb 11, 2004 | 10:01 AM
BigCrzyRdNeck
It hauls the 10,000 lb load pretty well considering the 21 years it has on it. On a normal day I can be heard upto around a mile away with no load. I'm hoping the 390 will be a little louder.
Old Feb 12, 2004 | 01:39 AM
bigric's Avatar
bigric
I noticed that the Performer 390 intake I got doesn't allow the dizzy to sit right in there either; I'm going to have to shave it slightly to make it go down. I thought that I was crazy until I read this thread.
Old Feb 12, 2004 | 10:07 PM
Fritolay's Avatar
Fritolay
the 390 with the stacks sounds awesome for about six months
after that when you get out of the truck constatntly saying huh what it gets old my dads 76 rattled so bad in the cab you couldnt here S$%#
as for the intake scrounge some scrap yards you may get lucky or just call your retailer of choice and get one
Old Feb 13, 2004 | 10:08 AM
BigCrzyRdNeck
Son I have been running a 351w with straight stacks for three years now and haven't said uh yet.
Old Feb 13, 2004 | 10:12 AM
BigCrzyRdNeck
I keep trying to hit a swap meet but don't know where to look to see when there in my area.
Old Feb 14, 2004 | 12:01 AM
Fritolay's Avatar
Fritolay
easy on the son stuff aihgt i only got one dad and u aint him (dont wanna start a fight just hate that term ) just sayin in a 76 it was loud and last time i looked a 76 was a lot of steel and an 82 had a lot of sound deadening matterial in the cab better acoustiics
the 76 in question has a rubber floor mat camper window and a cardbord headliner the only thing soft was the saddle blanket seat cover, the pipes came out 2" above the cab and about 3" behhind it no mufflers and 2 1/2" pipe out of 3" colectors so add it all up and u get to ge deaf if you stay in there too long
oh btw drop off a 9percent grade with five cord of fire wood on a goose neck over a two mile run and you get the equivelent sound of a twelve guage bein fired right behind your head every ten seconds = loud
Old Feb 16, 2004 | 07:23 AM
BigCrzyRdNeck
not to argue but no head liner and same floor liner for pipes look at my pictures
abeagle
Nov 4, 2015 01:25 PM
Jag Red 54
Nov 6, 2014 01:48 PM
Canadianice
Bronco II
13
Jun 28, 2007 06:30 PM
dogsniper
Apr 10, 2007 09:45 AM
4t6ford
Jan 26, 2005 10:33 AM
