Sponsored by: Auxito
intake noises
Old Feb 8, 2004 | 09:54 PM
flyguy2's Avatar
flyguy2
intake noises
I have a 2001 f-150 4x4 supercab with a 5.4 engine. On exelleration I hear a sucking noise in the engine. I've been told by the dealer that it is air being sucked through the intake and that this is a normal noise. It can only be heard at low speeds with the windows closed. Is this type of noise normal with this engine? Thanks.
Old Feb 8, 2004 | 11:19 PM
LxMan1's Avatar
LxMan1
Hi and welcome to the forum
I have basically the same truck and mine doesn't do that.
Jimmy
Old Feb 8, 2004 | 11:29 PM
czechyour6's Avatar
czechyour6
If it has an aftermarket throttle body, like 75mm then that might be it
Old Feb 9, 2004 | 08:42 PM
flyguy2's Avatar
flyguy2
Thanks for the replies. This is the second engine for this truck and the first one didn't do it. If anyone has any ideas where I might look I'd appreciate it. I do know that with all the plastic on the engine that any noise would be magnified.
Thanks Again
Old Feb 9, 2004 | 09:32 PM
LxMan1's Avatar
LxMan1
I would look into the air filter assembly and the air intake tube, It sounds like it may be leaking air somewhere.
Also, just for kicks, check the PCV hose assembly for cracks and a vacuum leak. Especially behind the throttlebody.
Jimmy
KIRRABO
Mar 10, 2013 06:22 PM
61 uni
Jul 19, 2009 06:46 PM
99 Sport
3.8 & 4.2L V6
Sep 15, 2008 07:05 AM
bertrbr
Feb 19, 2004 08:18 AM
opnekryan
Nov 6, 2003 10:55 AM
