electrical short
Old Feb 8, 2004 | 03:43 PM
DaverL's Avatar
DaverL
Question electrical short
Hello,
I am having a problem I have not been able to figure out yet. But I am continuing to try. Maybe you have had this problem??
I have a 89' L6 F-150 Lariat , the problem is my truck battery dies in 2 days if I do not drive it. The battery is brand new. It has been doing this even with the old battery, I noticed that when I turn the ignition key switch to go to start the truck.. That I do not hear the fuel pump go on.. That is because I believe it is already on... I just recently replaced the alternator w/ voltage regulator... This is because my truck charging capacity died so I replaced the alternator...
Any ideas??? Please write... Thanks! DaverL
Old Feb 8, 2004 | 04:42 PM
Mil1ion's Avatar
Mil1ion
You need to do a test for a Short or power Drain .
It is a process of elimination.
Old Feb 8, 2004 | 09:57 PM
Franklin2's Avatar
Franklin2
Try this test.
If the light comes on bright, and you think it may be the fuel pump, pull the fuel pump relay and see if the light goes out.
Old Feb 9, 2004 | 06:04 AM
DaverL's Avatar
DaverL
Thanks for your advice... Can I ask where is the fuel pump relay and what does it look like? Cause I think that may be it... Thanks! Daver
Old Feb 9, 2004 | 01:04 PM
Mil1ion's Avatar
Mil1ion
There are 2 pumps.
One in the fuel tank & one under the driver along the frame
Old Feb 10, 2004 | 08:04 AM
DaverL's Avatar
DaverL
Thanks for your help! I know where the pumps are.. but could you tell me where the relays are or what they look like?
Old Feb 10, 2004 | 10:33 AM
thelonerangerxlt's Avatar
thelonerangerxlt
I'm not sure about an 89, but fuel pump relays are usually under the hood in a "power distribution" box. It's usually on the driver's side fenderwell in front of the brake booster. The relay will be about 1-2 inches square, and pull out of it's socket. If the relay listing is not on the box cover, you'll have to pull them one by one until you find the correct one.....
Shutech
Apr 21, 2015 09:31 PM
jbc19d
2004 - 2008 F150
Sep 2, 2012 10:36 AM
XBuford
Nov 15, 2010 09:03 PM
jjohnson
1997 - 2003 F150
Oct 9, 2006 10:17 AM
