catalytic converter test?
Old Feb 7, 2004 | 04:34 PM
christaylor's Avatar
christaylor
I am ready to replace my exhaust system and want to make sure my cat is working properly. Is there any symptoms I should look for or a way to test it?/
Thanks
Chris
Old Feb 7, 2004 | 08:50 PM
bob arrington's Avatar
bob arrington
shops that replace them alot usually have a back pressur tester . it screws into the o2 sensor hole and measures the amount ig back pressure the cat is caucing. on your truck your computer would tell if there was something wrong , good luck,bob
Old Feb 7, 2004 | 08:58 PM
natewoz's Avatar
natewoz
An emissions test can also be a good indicator, but not too many folks have access to a gas analizer unless you work at a shop or for the DOT.
Old Feb 8, 2004 | 12:39 AM
christaylor
So if i pull the engine codes it will give me the ok or not on the cat?
next step. what cat back system would you recomend to improve HP and MIlage I was thinking flowmaster.
Chris
Old Feb 8, 2004 | 07:56 AM
bob arrington
yes it will, actually it will tell you if all is well, no codes , everything is fine. you wont see a whole lot of improvment unless you also go to high flow cats. you can only flow as much as they allow . your stock muffler is pretty restrictive, and if you wanted to go cheap, you could get a high flow muffler and a larger tail pipe and do the same thing,bob
HowieE
Aug 5, 2016 08:28 AM
opit36
Feb 18, 2012 09:01 AM
nickbaize
Mar 30, 2010 11:15 AM
quaders4ever97
Dec 17, 2008 01:29 PM
