Bronco II Ford Bronco II
Braking problem
Old Feb 7, 2004 | 04:11 PM
broncoray's Avatar
broncoray
Braking problem
When I Brake the car it is slowing down in a unpleasant way.
It thus not brake continuous but it rubes, it is not doing this always but most of the time.
My front brake discs are in good shape; also I noticed that if I drive over a thump and brake everything is fine. Good it be that the pressure regulator for the rear brakes is faulty?
Ray
Old Feb 7, 2004 | 06:04 PM
Ken00's Avatar
Ken00
I would suspect a warped disk or out-of-round drum if you mean its pulsating.
Old Feb 8, 2004 | 05:27 AM
broncoray's Avatar
broncoray
Hi ken,
This is what I thought to but then it shut show this symptom always that is not the case.
Sometimes the brakes work as they shut so I think it must be something different.
Ray
Old Feb 8, 2004 | 10:27 AM
dlink's Avatar
dlink
Could be the Master cylinder is going, I've had a simular problem,
some times the brakes felt liked they could launch you through
the wind sheild, and some times you felt like you had to use the
Fred Flinstone brake approach.
Old Feb 8, 2004 | 11:13 AM
broncoray's Avatar
broncoray
What I did not thel jet is that the braking pedal is feeling good all the times
Old Feb 8, 2004 | 06:40 PM
Ken00's Avatar
Ken00
Thats the only thing I can think of.
vacuumbed
Ford Truck Parts for Sale
Nov 14, 2013 06:46 PM
beckman
May 10, 2013 09:56 AM
ds086121
Mar 2, 2010 11:06 PM
pdrhodes1
Mar 24, 2009 12:20 AM
1975Ford
Oil & Lubrication
13
Jan 4, 2007 11:31 AM
