When I Brake the car it is slowing down in a unpleasant way.
It thus not brake continuous but it rubes, it is not doing this always but most of the time.
My front brake discs are in good shape; also I noticed that if I drive over a thump and brake everything is fine. Good it be that the pressure regulator for the rear brakes is faulty?
Could be the Master cylinder is going, I've had a simular problem,
some times the brakes felt liked they could launch you through
the wind sheild, and some times you felt like you had to use the
Fred Flinstone brake approach.
